PLEASE HELP... oil dip stick problem.....
Old Jun 21, 2008 | 12:09 AM
empireking13's Avatar
empireking13
Default PLEASE HELP... oil dip stick problem.....
i had my motor done about 2 months ago. the works.its an 88 twin cam in an 03 electra glide. turned it into a q106. did everything except lifters. even did a s/e oil pump. my problem is im getting to much pressure in the oil system and my dip stick keeps getting ejected from the bike. ive gone thru four of em now. i talked to godspeed ( who built the motor ) and he sais this has never happened to a 106 he has built. he thinks it might be the crank case breather or something to do with rsd air cleaner i have on the bike. every time i jump on it i lose the dip stick. please help!!!!!!!!!!!!!!!!!!!
[IMG]local://upfiles/56237/746609B123A847E19530A48B52A78638.jpg[/IMG]
[IMG]local://upfiles/56237/2E4B60FD2F6B44EAB47B304A56F15539.jpg[/IMG]
Old Jun 21, 2008 | 12:46 AM
1ADAM12's Avatar
1ADAM12
Default RE: PLEASE HELP... oil dip stick problem.....
Try the LCD dip stick it fits a little tighter&nbsp\\; good luck bro......
Old Jun 21, 2008 | 01:00 AM
empireking13
i tried the lcd but it got stuck on because of all the pressure and i had to pry it off and it broke into 2 pieces
Old Jun 21, 2008 | 06:27 AM
PhilM's Avatar
PhilM
Have you checked CCP, is it what it should be for the build? How 'bout a a leakdown test?
&nbsp\\;
The reason I ask those questions is that if you do not have properly seated rings and/or a good piston/cylinder fit, then you can have excessive blow-by which creates very high crankcase pressure and that can cause the problem you are having.
&nbsp\\;
Are you getting much oil blowing out the crank breathers (on the heads)?
Old Jun 21, 2008 | 08:00 AM
Neggy ZRXOA 5248's Avatar
Neggy ZRXOA 5248
Something is wrong.
Either there is huge blow by pressurizing the crankcase, or the breather is plugged.
checking the breather is the easiest thing to do so start there.
If that looks OK then I'd go for a leak down test of the cylinders and see if there was something amiss in the rings or machining of the jugs,
Old Jun 21, 2008 | 08:07 AM
Heathen's Avatar
Heathen
The problem might be your crankcase vent...Baker trans. has the cure for your problem.
Old Jun 21, 2008 | 08:44 AM
Donnylee's Avatar
Donnylee
Fully agree that&nbsp\\;it is excessive crankcase pressure.&nbsp\\; It it is either the inability for it to exhale or you have an abundance of blow by.
&nbsp\\;
&nbsp\\;
ORIGINAL: Neggy ZRXOA 5248
Something is wrong.
Brian Wittal
Jun 17, 2017 01:41 PM
gilb
Panhead
32
Dec 4, 2010 09:16 PM
howiedodat
Oil Archive (no new posts)
Apr 4, 2009 05:08 PM
TWAFXRP
Mar 4, 2009 05:37 PM
empireking13
Jun 21, 2008 12:51 AM
