big sucker question
Old Jun 23, 2008 | 01:15 PM
patrol557's Avatar
patrol557
Default big sucker question
This is probably dumb but what do u use to clean the air filter.&nbsp\\; do you guys use the k&amp\\;n cleaner?&nbsp\\; Thanks for the help.
Old Jun 23, 2008 | 01:17 PM
Malac Frost's Avatar
Malac Frost
Default RE: big sucker question
K&amp\\;N recharge kit...just go easy with the oil or you will leak all over the side of the bike.
Malac
Old Jun 23, 2008 | 02:15 PM
HOGinit's Avatar
HOGinit
The people at Ness told me to use the K &amp\\; N products to clean and oil the filter.&nbsp\\;
Old Jun 23, 2008 | 03:41 PM
flhf150's Avatar
flhf150
I use K&amp\\;N recharge kit. Go real easy with the oil. Learned from experience
Old Jun 23, 2008 | 03:52 PM
SG 1's Avatar
SG 1
ORIGINAL: Malac Frost
K&amp\\;\\\\\\;N recharge kit...just go easy with the oil or you will leak all over the side of the bike.
Malac
&nbsp\\;
Cleaned and Recharged mine 2 weeks ago.&nbsp\\; Its still leaking, but I think its almost done.&nbsp\\; So yeah, try to go easy on the oil.
Old Jun 23, 2008 | 04:15 PM
iclick's Avatar
iclick
S100 or Simple Green both work well, but follow the correct procedure: Spray cleaner, let sit for 10 min., rinse with slow-running water from the inside of the filter element, gently sling the excess water out but don't try to blow-dry it with a compressor, then let dry overnight before oiling.
mikeo33y
Nov 3, 2013 01:54 AM
penick33
Jun 3, 2008 09:38 PM
conroskie
Feb 21, 2008 01:02 PM
iclick
Exhaust System Topics
Aug 21, 2007 10:13 AM
parakiller
Apr 20, 2007 02:57 PM
