Thanks for info folks, the dealer did bevel the leading edge of the pads and it was good for the first day....I have ordered the Lyndall Z plus pads today and will let you know if they work.
As for the bike leaning to the left I'm taking to dealer to get alignment checked..thanks for the advice
I too have had a rear brake squeal on my "08 EG since day one. \\; I complained to the dealer and to the MOCO directly. \\; The dealer scruffed the pads (it didn't work) and told me to adjust my braking methods. \\; The MOCO told me they had other complaints and were looking into a fix. \\; I won't hold my breath for a fix.
I have about 4500 miles on my 04 Deuce, and I started getting the brake squeal, front and back, at around 3000 miles. Not sure what to do about it, maybe I'll look into replacing the brake pads with aftermarket pads.
I had the gold pads and they squealed more. \\; They replaced with regular Z plus and the rear brakes are much quieter. \\; Customer service is the best at Lyndall. \\;
I put Lyndall Gold pads on the rear of my Dyna. After a couple thousand mile they are starting to squeal. Stop good. Little brake dust.
But annoying.
Gonna have second thoughts about what goes on the front.
There's a service bulletin out which addresses this problem and was posted on this forum earlier.
Service Bulletin M-1228 dated July 31, 2008, applys to 2008 and 2009 Touring models including CVO models manufactured before July 7, 2008. This involves the "application of Anti-Noise kit #42551-08."
This is "designed to address Rider complaints of high frequency Rear Brake squeal under light load and low speed braking."
A copy of the Service Bulletin was posted by DAWG shortly after it came out. Gotta love that guy.
I have found most pad squeels it actually the back pad.I gut some moly paste and put a light coat on them and heated it in with a small propane torch and it never made any more,ever.Be sure to to the metal backing and not the pad its self.
I have same bike with both problems. How did you make out with the
leaning or pulling to the left?
