hd amp kit
Old Jul 2, 2008 | 12:25 PM
VINNIE JAMES's Avatar
VINNIE JAMES
Default hd amp kit
mine is mounted under my tour pack. does anybody have an amp mounted some place else? pics? i want to be able to remove my tour pack and not have any problems. thanks, vinnie
Old Jul 2, 2008 | 12:30 PM
NICK56's Avatar
NICK56
Default RE: hd amp kit
same
Old Jul 2, 2008 | 12:37 PM
Beeracuda's Avatar
Beeracuda
Mine is mounted under the right side cover.&nbsp\\; The ignition box was moved to under the seat.&nbsp\\; My bike is carbed, so the ignition box is small enough to go there.&nbsp\\; It probably wouldn't work with an injected bike....
Old Jul 2, 2008 | 01:13 PM
ElectraGlideClyde's Avatar
ElectraGlideClyde
&nbsp\\;All of the Ulra's have the amp mounted under the TP.&nbsp\\; Because of the wiring, the only other place it can put is in a saddlebag.&nbsp\\; It can be removed completely and the system will work fine.&nbsp\\; The amp is for the 160 watt system.
&nbsp\\;
Old Jul 2, 2008 | 01:42 PM
VINNIE JAMES
if i remove the amp. how much of a difference is it? and what do i do with my antenna's? is there an upgrade for them? thanks
Old Jul 3, 2008 | 05:39 PM
bunt's Avatar
bunt
You can put Hawg Wired in the fairing, remove overlay harness. Ams are digital so little or no heat buildup in fairing. 300 watts sound goooood!
[IMG]local://upfiles/34350/6D5CAA677D4444F8A33002E10C97F7EF.jpg[/IMG]
Old Jul 4, 2008 | 04:42 AM
Badbagger's Avatar
Badbagger
I've got two amps mounted in my fairing and didn't want to have any issues with the quick detach setup. Just unplug the quick disconnect for the rear speakers and take off the tour pak.
Old Aug 4, 2008 | 04:01 PM
VINNIE JAMES
ok i put the tour pak removal kit on. what do i do with my amp now? the fairing speakers don't work. i would put it in the right side bag but the plug is huge. if i change the amp what do i do with all the riders? thanks,vinnie
Old Aug 4, 2008 | 04:13 PM
blueflht's Avatar
blueflht
there are a number of amps that will fit in the fairing. a hawg wired amp is way to much money for the power it provides. u can do much better cheaper
Old Aug 4, 2008 | 06:00 PM
VINNIE JAMES
well i already have the amp. any pics of what people did for a amp? what do i do what all the wires?
