Changing my own tires
Old Jul 2, 2008 | 12:34 PM
ironhead3fan's Avatar
ironhead3fan
Default Changing my own tires
I read about a lot of you changing your own tires What equipment do you need to do this at home, and where did you get your equipment from? Yes, I have the service manual. My indy hits me for an hour labor each time he does it. With this economy, I think I am going to start doing it myself. Thanks.
Old Jul 2, 2008 | 12:39 PM
IBHarley's Avatar
IBHarley
Default RE: Changing my own tires
http://www.harborfreight.com/cpi/cta...emnumber=42927&nbsp\\;or some tire iron/spoons and a bead breaker
Old Jul 2, 2008 | 12:43 PM
honestbob's Avatar
honestbob
I got my bead breaker and tire irons from J+P cycles. Works real good, might want to order a couple of rim guards -couple of bucks
Old Jul 2, 2008 | 01:05 PM
NICK56's Avatar
NICK56
1st&nbsp\\; a frame&nbsp\\; jack..&nbsp\\;
Old Jul 2, 2008 | 01:06 PM
NICK56's Avatar
NICK56
bring the&nbsp\\; tire&nbsp\\; with old rubber&nbsp\\; to ur&nbsp\\; dealer&nbsp\\; let them&nbsp\\; do it..&nbsp\\; way&nbsp\\; easier&nbsp\\; than&nbsp\\; braking ur&nbsp\\; ***** on&nbsp\\; dismount and&nbsp\\; mount..plus&nbsp\\; how can u do a&nbsp\\; hi speed balance?
&nbsp\\;
Old Jul 2, 2008 | 02:07 PM
G wizz's Avatar
G wizz
&nbsp\\;
I bought a NO-MAR tire changer off the web, It has paid for itself in the two years I've owned it. Works well, fast, and easy, also it can't mar your wheels, as no metal touches the wheels.
Look up No-MAR motorcycle tire changers on the web, you'l find it.
I might add, my whole family rides, we have a dozen bikes to keep up, it would be fooli$h to take them to the dealer evey time one needed a tire change.
&nbsp\\;
&nbsp\\;G wizz
&nbsp\\;
Old Jul 2, 2008 | 02:25 PM
nomad billy's Avatar
nomad billy
1-2x4,8 ft long,cut 2 ft off the 2x4,put the short piece on the tire ,long piece under the bumper of&nbsp\\; your truck,car whatever.Break the bead,2 extended tire spoons,pop the tire off.Coffee cup full ,half water half dishsoap.Take a rag ,dip it in the cup an wipe the bead,pop the tire back on,put the right amount of dyna beads in,air it up ,put it back on.Takes about an hour to do both,after you learn how.Generous amount of shop rags,blanket off the bed,whatever you can find to put under the rim so concrete doesnt scar up the wheel.Good to go
Old Jul 2, 2008 | 04:03 PM
Jinks's Avatar
Jinks
ORIGINAL: ironhead3fan
There's a lot of ways to change tires.&nbsp\\; If you take 'em off with tire irons, consider puttin' the new tire on with a rubber mallet.&nbsp\\; Easier than the tire irons, &amp\\; you don't need the rim protectors.
If you want to do it the easy way you'll spend $200 to $400 on tools to get started, but it'll pay you back quickly.&nbsp\\; I use a Harbour Freight changer with the motorcycle adapter to break the bead &amp\\; hold the rim while I remove the old tire &amp\\; put the new one on.&nbsp\\; I have a Marc Parnes www.marcparnes.com static balancer to balance the wheel first, &amp\\; the tire/wheel combination when I'm done.
Go to home.comcast.net/~prestondrake/mojoweb.htm for a mount/dismount bar that works with the Harbour Freight changer &amp\\; won't damage your wheels.&nbsp\\; It's worth the investment, &amp\\; makes the job a lot easier.&nbsp\\; Pick up some weights at NAPA, a large "C" clamp, a couple of large tire irons, &amp\\; a set of rim protectors &amp\\; you're good to go.
Old Jul 2, 2008 | 04:07 PM
Sharknose's Avatar
Sharknose
http://www.clarity.net/~adam/tire-changing-doc.html
Old Jul 2, 2008 | 08:48 PM
iclick's Avatar
iclick
Two years ago I went in with three others and invested in the necessary tools to change tires.&nbsp\\; Here are some links:
http://www.harborfreight.com/cpi/cta...emnumber=34542
http://www.marcparnes.com/
http://home.comcast.net/~prestondrake/mojoweb.htm
You'll also need 3-4 tire tools, some plastic (e.g., milk cartons, old auto floor mats, etc.) to protect the rim from the tire tools and changer, RuGlide (lubricant), and some stick-on weights (Napa, HD, etc.). The Mojolever is necessary if you want to use the motorcycle adapter on the HF changer, as the standard rod is bare steel and will scratch alloy or chrome wheels. The Mojolever has nylon tips and is a big improvement for a premium price. You can do the job with two people and only the HF changer, tire tools, lubricant, plastic, etc.\\; i.e., no MC adapter or Mojolever. Doing it this way is a wrestling match, especially D402's with their difficult bead arrangement, but anyone can do it with a little practice. One you do it a few times you'll have it down and won't look back, even though there is a learning curve. None of the four in our group are sorry we made this investment.
We bought our HF changer, adapter, and Parnes balancer used for $75, a real steal. Buying new you'd be looking at about $350 or so for the caboodle, and split four ways you'd probably more than break even the first tire change.
