Need Help Please
Old Jul 5, 2008 | 03:00 PM
Maxcustody's Avatar
Maxcustody
Default Need Help Please
Here's the story.
&nbsp\\;\\\\\\;
06 Street Glide 95 inch with 251 cams, if that matters. T rex true duals, compression releases.
&nbsp\\;\\\\\\;
I was riding home from work today, cruising at 70 mph, all of a sudden both tach and speedo gauges drop to zero, lose all power, luckily I got it over to the side when I got it stopped no power at all, motor was off. Plenty of juice no battery problem. I turned ignition off. Turned ignition back on, pushed compression releases, let EFI cycle and the bike fired right up. Drove away running good. Got about 5 miles from home and it did same thing again, didn't pull over this time,&nbsp\\;\\\\\\; I opened the throttle a couple of times and it went back up to speed slowly. Any ideas? Thanks&nbsp\\;\\\\\\;&nbsp\\;\\\\\\; Scott
Old Jul 5, 2008 | 03:31 PM
dionne51's Avatar
dionne51
Default RE: Need Help Please
From reading recent posts, this could be the issue with the fuel filter I've read about.&nbsp\\; Search for fuel filter and you'll get many hits.
Old Jul 5, 2008 | 03:42 PM
Maxcustody's Avatar
Maxcustody
Thanks
Old Jul 5, 2008 | 04:19 PM
porkster's Avatar
porkster
The thing with the fuel fiter canister is existant in the 08's haven't heard of that problem with the 06's.
Old Jul 5, 2008 | 04:46 PM
Maxcustody's Avatar
Maxcustody
I did a search on fuel filter, sounds to me maybe there are tiny pin holes in fuel line inside tank and may have caused this. I called the dealer as soon as I got home. How much are they gonna charge me to fix this I wonder? New fuel filter and fuel line.
Old Jul 5, 2008 | 10:22 PM
glens's Avatar
glens
ORIGINAL: Maxcustody
... all of a sudden both tach and speedo gauges drop to zero, lose all power... and the bike fired right up. Drove away running good. Got about 5 miles from home and it did same thing again...
Your fuel line might have holes worn into it, who can say? But your story sure has all the earmarks of an electrical glitch.
Old Jul 6, 2008 | 02:03 AM
mjmangus's Avatar
mjmangus
Exactly. Running out of fuel wouldn't cause the speedo to stop.&nbsp\\;I've heard that there have been some problems with the breaker. You might check it out.
Old Jul 6, 2008 | 03:46 PM
Maxcustody's Avatar
Maxcustody
I checked the battery connections, all are tight. I checked the plug wires as well. I am going to take it in to the dealer tomorrow, hopefully they don't rape me too bad. There are too many things it can be.
Old Jul 6, 2008 | 04:02 PM
UltraKla$$ic's Avatar
UltraKla$$ic
There was a batch of bad Voltage regulators in '06.&nbsp\\; Maybe yours is about to take a dump.
Old Jul 6, 2008 | 04:19 PM
Maxcustody's Avatar
Maxcustody
I think I had it changed once already. I will bring that up tomorrow as well. I am writing a list when you guy's give me tips. Thanks.
