Ultra fairing question
Old Jul 5, 2008 | 10:57 PM
mhonn2220's Avatar
mhonn2220
Default Ultra fairing question
I have had the center windsheild fairing insert come loose and when I got the outer fairng off I discovered that the plastic area where the new insert screws into has cracked. Short of getting a new inner fairing is there a good way to repair the inner fairing? I was thinking of trying JB WELD or Gorilla Glue. Any ideas will be greatly appreciated.
Old Jul 5, 2008 | 11:07 PM
MikeMihelich's Avatar
MikeMihelich
Default RE: Ultra fairing question
JB Weld works great.&nbsp\\; I used on my valkyrie fairing when the inserts on it failed. It held fine.
Old Jul 6, 2008 | 05:38 AM
stro1965's Avatar
stro1965
I have the same problem right now on the far lower left screw hole.&nbsp\\; Cracked around the insert.&nbsp\\; Next time I have the fairing off I thought I'd fix it up with JB Weld.&nbsp\\; If you try first, let me know how it works!
&nbsp\\;
Old Jul 6, 2008 | 08:16 AM
blueflht's Avatar
blueflht
i would use a fiberglass patch kit
Old Jul 6, 2008 | 11:37 AM
mhonn2220's Avatar
mhonn2220
ORIGINAL: stro1965
I have the same problem right now on the far lower left screw hole.&nbsp\\;\\\\\\; Cracked around the insert.&nbsp\\;\\\\\\; Next time I have the fairing off I thought I'd fix it up with JB Weld.&nbsp\\;\\\\\\; If you try first, let me know how it works!
&nbsp\\;\\\\\\;
&nbsp\\;
I will do that. If you try it before I do let me know how it turns out.
Old Jul 6, 2008 | 12:58 PM
stro1965's Avatar
stro1965
Okay, no plans to pull the fairing in the near future though, that sucker has been on and off so much it's no wonder one of them cracked!&nbsp\\;
B@man
Feb 27, 2013 12:11 PM
dspencer
Sep 15, 2008 06:01 PM
ricaroo
Apr 17, 2007 11:50 AM
parrot
Sep 16, 2006 05:32 AM
jdag
May 10, 2006 05:55 PM
