Heat Shield comparisons + xieds
Old Jul 6, 2008 | 06:49 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
Default RE: Heat Shield comparisons + xieds
got the xied on last week seems to run cooler runs stronger in lower rpm doesnt stumbble out the hole and the pinging is gone (probably cause its not as hot) milage dropp is less than 2 miles a gallon,after 4 tanks.oil cooler is next
Old Jul 6, 2008 | 07:11 PM
smitty901's Avatar
smitty901
As for the Xied's here is what I found I have no dog in the race and nothing to do with Nightrider.
&nbsp\\;
I bought a set to play with. Xied'sInstalled them on a 2007 Road glide with 16,000 miles on it. The bike is stock and has always run fine.Install took all of ten minutes.The bike runs well with them.Throttle responce is a bit stronger.Bike sounds a little deeper.Roll on from 60 in sixth gear is stronger.As for heat I tested these over two weeks on rides I make alot. I used a thermal gun and took temps in 6 places. I ran the bike with and with out the Xieds many times on the same runs and conditions.while at times they did lower the temps a small amount it was never over 20 degrees and temps did work thier way back up if the bike was left sitting. However they did appear to slow the heat rise a bit.They did cost me a small amount of fuel milage.Over all they do just what Nightrider claims for me. They do NOT reach some of the out landish claim I have seen posted about them.And heres some food for thought I decide to check temps on my 96 Fatboy with a stage 1 done to it come to find out they are not much different than the 07 ?With that in mind last weekend at Lacrosse WI there were a lot of motorcycles at the S&amp\\;S party .I did random checks of engine temps of all kind of bikes that were riding together.There was every mod and trick you can image there. Seems none of the temps veryed that much.I have found that many using a thermal gun are some what fooling them selfs.It is very improtant that the gun be pointed at the same spot same angle and same distance everytime to get a true reading to compare. And not on crome.While playing with mine just a hair differnce in some spots made a 40 to 50 degree difference. To get true readings I made two rods taped to gun to hold angle and distance and marked each spot.
Old Jul 6, 2008 | 07:21 PM
BlackBagger's Avatar
BlackBagger
Xied + RJ = The way to go
&nbsp\\;
Mg
&nbsp\\;
&nbsp\\;
Old Jul 6, 2008 | 10:54 PM
LebanonRider's Avatar
LebanonRider
I agree with the potential for error using the digital temperature gauge, but I take about 2 or 3 readings in the same area and use the 'average'.&nbsp\\; Actually, on mine, I can hold down the button and move it around a little.&nbsp\\; The gauge indicates the last reading but has a smaller readout that also shows the highest reading.&nbsp\\; At any rate, I wouldn't use it as an absolute to compare with others, but since I do it the same way every time, the relative results should be valid.&nbsp\\;
Old Jul 7, 2008 | 11:13 AM
SSJ's Avatar
SSJ
ANy of the heat shields will work just fine depends on what you want to spend and the look you want, I got the Kury clears and happy with them.
hAkron
Jul 12, 2017 09:33 PM
capt945
Aug 16, 2007 07:52 PM
Bluerose
Aug 14, 2007 06:42 PM
rhino49er
Jul 26, 2007 08:30 PM
deadeye
Jul 1, 2007 06:43 AM
