07 flht adding tour pack
Old Jul 11, 2008 | 05:51 AM
patsac's Avatar
patsac
Default 07 flht adding tour pack
07 standard, got a good deal on a tour pack, question is,, does the standard have the wire harness for the lights allready on the bike?
Old Jul 11, 2008 | 05:55 AM
dawg's Avatar
dawg
Default RE: 07 flht adding tour pack
Assuming you mean the tour pak brake lights and side marker lights?&nbsp\\;If so, no you would need to buy the ultra tourpak wiring harness.
Old Jul 11, 2008 | 06:44 AM
Drew's Avatar
Drew
On my '07 FLHT, the basic 3-wire (run, brake, ground) harness was bundled with the antenna cable beneath the left side cover. I used this to plug in my tour-pak side lights, and air-wing brake/runnning light.
Old Jul 11, 2008 | 07:22 AM
1badbagger's Avatar
1badbagger
Same on my 2003, the wire was there already, same place as mentioned by Drew.
Old Jul 11, 2008 | 07:31 AM
RD GLD's Avatar
RD GLD
08 Road Glide and wires were bundled there as well.
Old Jul 11, 2008 | 07:53 AM
dawg's Avatar
dawg
To clarify my post, I believe that if it is an Ultra tourpak that you got, then you would need the ultra wiring harness, I believe the only harness attached to scoot is the regular one, could be wrong though
Old Jul 11, 2008 | 10:01 AM
Harleypingman's Avatar
Harleypingman
If you are getting an Ultra box (side marker lights and rear light bar), the wiring for those is a single harness that connects to the three wire connector that others have mentioned that is already on the bike as part of the Main wiring harness.&nbsp\\; If you have a pre-06 TP that has the side marker lights only, it also uses the three wire connector that is already on your bike.
&nbsp\\;
All of the Touring models, except Road Kings, have the TP harness for connecting TP lights.&nbsp\\; But on an Street Glide, the three wire connector is used for the rear fender facia LED.
wharfcreek
Electrical/Lighting/Alarm
Oct 11, 2018 07:48 AM
Mike02
Apr 9, 2016 12:08 AM
lhinaz71
Jul 29, 2015 08:34 PM
bonez
Dec 8, 2006 08:09 AM
