Wiring lights for tour pack
Old Nov 26, 2011 | 09:36 PM
Mike02's Avatar
Mike02
Stage I
Default Wiring lights for tour pack
I have just purchased a tour pack for my 2010 Streetglide CVO and the the Detach 2 up mount. I'm wiring it for the wraparound LED brake/running lights, side marker and brake/running light on Air Wing rack. Has anyone else had this much fun?
Old Nov 26, 2011 | 10:09 PM
mkguitar's Avatar
mkguitar
Yup.
I work with electronics so it was easy for me.
I think harley sells "Y" adapters that just plug in if you want to do that, you'll need a couple or 3 of those
I replaced the factory wiring harness with a flat 4 trailer plug, spliced in under the seat, the flat 4 wiring, then goes down under the side cover and along the frame rail.
( ground, run, brake ...and the 4th is wired to the accessory)
loop velcro is stuck onto the shock, hook velcro is a wrapped around the plug, which has a cover and test leds built in.
the other end is wired inside the tour pack the ground run and brake wired into all the right stuff with crimp connectors, and the 4th accessory in run to interior led lighting for the tour pak ( adapted ikea under cabinet lighting-- no more flashlight in the mouth, digging around) and to "lighter" and usb outlets for charging my phone/ipod/cameras and other junk going down the road
I have apiece of loop velcro stuck to the inside of the tourpak rack, and when the plugs are connected, I just stick them there
It's not hard, just lay in out and think if you might want to add anything--- like the tour pak lid organizer--- do that before you do the wiring for the airwing.
I think the stock color coding is blk- ground, blue- run, red -brake
use crimp connections if you do your own.
soldered connections do not hold up well on bikes ( no matter what you see on american chopper!)
mike
Old Jan 3, 2012 | 08:21 PM
Whiskersvtwin's Avatar
Whiskersvtwin
If I could only find the delete post button.. ughhh
Old Apr 8, 2016 | 07:00 PM
prophet579's Avatar
prophet579
Stage I
Do you happen to know the part number for the Y connector for the tourpak lights
Old Apr 9, 2016 | 12:08 AM
mkguitar's Avatar
mkguitar
Welcome to the Forums-
I don;t know the number but you can browse the HD parts and accessories online.
once you figure out teh part, look online for a deal- and don;t overlook teh forum classifieds, lots of fair deals there
mike
wharfcreek
Electrical/Lighting/Alarm
Oct 11, 2018 07:48 AM
JHL-ShinySideUp
Mar 18, 2017 01:14 PM
nichiowa
Jul 17, 2014 06:21 AM
toyking23
20
Apr 24, 2007 10:34 AM
