pcIII question
Old Jul 12, 2008 | 12:46 PM
river rat's Avatar
river rat
Default pcIII question
&nbsp\\; Does removing the PCIII have any adverse affects to the ecm. I'm looking to go back to the stock setup.&nbsp\\;The bike came with only Sampson drag pipes added and the PCIII. The OEM pipes are going back on. I know I"m in the minority here, I just prefer a stock setup.
Old Jul 12, 2008 | 12:57 PM
EastSideBikerTrash's Avatar
EastSideBikerTrash
Default RE: pcIII question
No.&nbsp\\; The PCIII does not make any permanent changes to your bikes configuration.&nbsp\\; Remove it and the ECM&nbsp\\;system will be exactly as it was before the PCIII.&nbsp\\;
&nbsp\\;
hth,
Dave
Old Jul 12, 2008 | 01:00 PM
EastSideBikerTrash
Here some technical info.&nbsp\\; Read&nbsp\\;this &gt\\;&nbsp\\;'Do I need a Power Commander and how does it work?'
&nbsp\\;
http://fuelmotousa.com/faq.htm
&nbsp\\;
dave
&nbsp\\;
Old Jul 12, 2008 | 01:04 PM
MotorSgt's Avatar
MotorSgt
what are you doing with the old pipes? What syle are they I have been thinking about getting some. If your wanting to get rid of them I may be interested.
Old Jul 12, 2008 | 01:21 PM
river rat's Avatar
river rat
&nbsp\\;Thanks for the reply. Would riding it a short length of time (50 miles) with the stock mufflers on, do any damage to the motor, til I get a chance to remove it?
Old Jul 12, 2008 | 02:29 PM
glens's Avatar
glens
All you have to do is pull the sidecover, disconnect the harnesses, put the bike harness back into the ECM, pull your O2 eliminators and reconnect the O2 sensors. Should take about 3 minutes on the side of the road. You can pull the PC-III out later.
Old Jul 12, 2008 | 08:53 PM
skratch's Avatar
skratch
ORIGINAL: river rat
&nbsp\\;\\\\\\;Thanks for the reply. Would riding it a short length of time (50 miles) with the stock mufflers on, do any damage to the motor, til I get a chance to remove it?
no, as a matter of fact, you could put the bike back into stock configuration in ref to pipes and air cleaner and get a map for the pciii that would richen up the fuel mixture a little bit and help it to run cooler.
Old Jul 12, 2008 | 10:26 PM
glens's Avatar
glens
The fully-stock engine package has got plenty of fuel in open-loop operation. Allowing O2 sensor operation (assuming current model) will cause removal of any extra fuel provided by the PC-III. It would cause removal of that same proportion of fuel from the open-loop areas. Not good. It would also screw with the adaptive fueling capabilities, which are the main selling point of allowing closed-loop operation.
Old Jul 12, 2008 | 11:01 PM
river rat's Avatar
river rat
It's an 06 model. Did the 06's have 02 sensors?
Old Jul 13, 2008 | 02:13 AM
glens's Avatar
glens
No.
