IDS removed
Old Jul 12, 2008 | 04:56 PM
skyryder's Avatar
skyryder
Default IDS removed
I have removed the IDS from my bike. I had done this before because I was geeting a noticible rear wheel noise on the left side. I retourqued everything and put it back on. I removed it again for the same reason and pulley had a noticible wobble when I was checking everything. The bearing looks good and nothing appears out of whack that I can tell. I have a noticible wear point that you can see in the picture. I checked rear wheel alignment and all seems good. I placed the old pulley on and everything seems fine and true and the noise is gone. Anyone have any ideas what could cause this?
[IMG]local://upfiles/19196/2073E190B9BF417D828686F4B952F0CA.jpg[/IMG]
Old Jul 12, 2008 | 04:58 PM
skyryder's Avatar
skyryder
Default RE: IDS removed
trying to post pic
Old Jul 12, 2008 | 05:08 PM
WindowMan's Avatar
WindowMan
you have to click on the red x,
site is a little messed up but they are working on it.
Old Jul 12, 2008 | 05:10 PM
skyryder's Avatar
skyryder
OK Click on red x it comes up.&nbsp\\; Thanks
Old Jul 12, 2008 | 05:16 PM
UltraKla$$ic's Avatar
UltraKla$$ic
How many miles on the IDS did you have?
Old Jul 12, 2008 | 05:17 PM
UltraKla$$ic
did you use red loctite? Is there any galling on the surface of the IDS where the bolts mate to the surface?
Old Jul 12, 2008 | 05:20 PM
glens's Avatar
glens
Isn't there supposed to be a spacer on the axle to prevent that? Maybe the bearing was pressed too far in or something.
Old Jul 12, 2008 | 05:33 PM
skyryder's Avatar
skyryder
I used red loctite the second install.
I have about 4000 miles on the IDS.
I usedt the correct spacers.
Can the bearing be pushed in too far?
Old Jul 12, 2008 | 05:37 PM
skyryder's Avatar
skyryder
There is no galling in that area
Old Jul 12, 2008 | 05:53 PM
skyryder's Avatar
skyryder
Everyone must be out riding
