Stock decel popping
Old Jul 13, 2008 | 06:45 PM
rsofa's Avatar
rsofa
Default RE: Stock decel popping
ORIGINAL: Snuffy1
It could be so small you can not find it. With a v-twin&nbsp\\;\\\\\\;it could be sucking a little air back in one pipe. Or a small leak around a O2 sensor.
Just a guess. I've seen it before. Let the dealer check it out for sure since it is still in warranty.
I'll have to check with another dealer as this one says it's normal go figure!!
Old Jul 13, 2008 | 07:14 PM
Bertk's Avatar
Bertk
ORIGINAL: rsofa
What's the best way to find the leak?? I see no visible signs of a leak around the connections....
&nbsp\\;
Check the muffler clamp for tightness. Tighten up to 65 ft-lbs
&nbsp\\;
Posted by Doc1: Take a 3/8 or 1/4 hose about 18~20' long, put one end to your ear and the other end sweep around the exhaust gasket area at the head....if it's leaking even a little bit you will hear a CRACKING or TICKING through the hose.
&nbsp\\;
Flange tightening:
Tighten the top nut of the front cylinder head exhaust flange to 9-18 in-lbs.
Tighten the bottom nut to 100-120 in-lbs
Then&nbsp\\;the top to 100-120 in-lbs
Reverse the process on the rear cylinder by starting with the bottom bolt
Old Jul 13, 2008 | 08:10 PM
rsofa's Avatar
rsofa
ORIGINAL: Bertk
ORIGINAL: rsofa
&nbsp\\;\\\\\\;
&nbsp\\;\\\\\\;
&nbsp\\;\\\\\\;
Flange tightening:
Then&nbsp\\;\\\\\\;the top to 100-120 in-lbs
Thanks I'll check it out I would have thought they would have on the 1k service I just had done 700 m ile ago!
Old Jul 13, 2008 | 08:43 PM
Bertk's Avatar
Bertk
ORIGINAL: rsofa
&nbsp\\;\\\\\\;
I may not be an exhaust leak but a leak has to be ruled out. Check the O2 sensor connection also
Old Jul 13, 2008 | 08:47 PM
2005UltraNC's Avatar
2005UltraNC
Yep, something wrong.&nbsp\\;Either intake or exhaust leak.&nbsp\\;
Old Jul 13, 2008 | 09:00 PM
tslonige's Avatar
tslonige
cool trick, Bertk, thanks for that little tip
Old Jul 13, 2008 | 09:19 PM
Bertk's Avatar
Bertk
ORIGINAL: tslonige
&nbsp\\;
You're very welcome&nbsp\\;
Old Jul 13, 2008 | 09:34 PM
papifun's Avatar
papifun
got 700km on my bike today and started to le the RPM's go up a little.. i get the popping noise when i accelerate to 4500RPM and then back off the throttle. all is stock except for SE heavy breather.
Old Jul 13, 2008 | 10:43 PM
Bertk's Avatar
Bertk
ORIGINAL: papifun
&nbsp\\;
What is happening is that the ECM cant compensate for the installed add-ons.
I would start by removing the heavy breather and see if it runs better.
Old Jul 14, 2008 | 12:06 AM
glens's Avatar
glens
ORIGINAL: Bertk
I would start by removing the heavy breather and see how it runs better.
Either that or get the download for it (which seems should have been included in the description of changes).
