knocking sound from primary
Old Jul 19, 2008 | 10:29 PM
dontdropit's Avatar
dontdropit
Active Streak: 30 Days
Active Streak: 60 Days
Default knocking sound from primary
i have a knocking sound in the rear of the primary. this is not the the start knock that so many complain about. at a cold&nbsp\\;start up there is a noticeable knocking at the rear of the primary, not very heavy or loud but i can hear it slightly. after the engine warms up the sound is gone. i noticed this about 500 miles ago, at that time the engine had 7000 miles on it. my bike is a 07 bagger all stock. anyone know what it is? once again it is only heard on a cold engine, after riding the bike and it gets completely warmed up the sound is gone.
Old Jul 20, 2008 | 09:19 AM
SteveB FLH's Avatar
SteveB FLH
Default RE: knocking sound from primary
It is probably the self-adjusting primary tensioner.....
Old Jul 20, 2008 | 09:33 AM
SoCal_Pappy's Avatar
SoCal_Pappy
+1 Are you using SYN in the primary?
Old Jul 20, 2008 | 11:19 AM
dontdropit's Avatar
dontdropit
no i'm using 10w40 motor oil. i thought it might be the compensator but that's at the front of the primary but sounds do echo in there. it might be the auto tensioner, time will tell i quess.
Old Jul 20, 2008 | 01:21 PM
iclick's Avatar
iclick
Same problem here using same viscosity, changed to 20w50 Castrol GTX and I haven't heard it in months.
Old Jul 20, 2008 | 05:28 PM
SteveB FLH's Avatar
SteveB FLH
You could try to accelerate in first gear to about 25 mph then firmly step on rear brake do not pull in clutch til you absolutely need to. try it couple of times...should work...will reset tension.
Old Jul 20, 2008 | 07:02 PM
dontdropit's Avatar
dontdropit
thanks, i'll give it a try.
As-21
EVO
Apr 11, 2019 01:42 PM
Huggerbugger
Nov 28, 2018 05:00 PM
JeffJA
Sep 18, 2013 12:32 PM
piperman
Oct 13, 2008 11:52 AM
Harley kevbro
Sep 13, 2007 06:56 AM
