Commander tire pressures??
Old Jul 26, 2008 | 10:34 AM
bagman1's Avatar
bagman1
Default RE: Commander tire pressures??
I ran metzlers and the rear said 51. Go by whats on the tire sidewall. The guy at Michelen is full of ****. The HD manual is for their oem std Dunlop tires. ALWAYS FOLLOW THE TIRE CASING NUMBERS!
Old Jul 26, 2008 | 10:50 AM
rkadair's Avatar
rkadair
number on the sidewall is max pressure for max load I bet you don't run 50lb in your car tires if you go check I bet its 32
Old Jul 26, 2008 | 11:01 AM
bagman1's Avatar
bagman1
youre right it is max psi which is to be followed if you are going to be at GVWR. I guess I should have been more clear but say a Dunlop says 41 and a Metzler says 51. If you ran 36, you would only be 5 psi under on a Dunlop which is acceptable, but on a Metzler you would be a dangerous 15 psi below their recommended limit, especially with 2 up. This would create more heat and casing fluction which will increase the chance of catastrophic tire failure.
I have dealt with different tire and wheel manufacturers and involved in law suits, and it came down to did you or did you not follow the stated tire psi on the tire?
Old Jul 26, 2008 | 11:05 AM
Coolhawg6622's Avatar
Coolhawg6622
So how do they compare to the Dunlops??? stickier?? better ride??? same???
Old Jul 26, 2008 | 11:19 AM
bagman1's Avatar
bagman1
IMHO I think Dunlop is a harder rubber which will give you longevity, Metzler is a softer compound which rides much nicer, but doesn't have the longer life as the Dlop, and Avon is even a softer rubber and from what Ive heard has superior sticking ability and is a great ride, but has the least life of the 3 tires mentioned.
I want to look at the Pirellis, Michelens possibly for the next go around, but I need to do more research before I change from Metzler.
Old Jul 26, 2008 | 03:34 PM
Taterdog's Avatar
Taterdog
Commanders seems to be a better ride than lops, and sticker, but probably won't last as long.&nbsp\\; I've only got 300 miles on my Commanders.
Old Jul 26, 2008 | 03:59 PM
GGC's Avatar
GGC
The Factory could learn a lot&nbsp\\;from all You self appointed Experts!
Old Jul 26, 2008 | 06:11 PM
GGC's Avatar
GGC
damit killed another one!
Dogwood's Avatar
Dogwood
I run 40/38 and I have 6000 miles, so far, very little wear.
Better ride, better traction, better handling than Dunlops, Metzlers, or Continentals (these are the only brands I've tried).
Old Jul 26, 2008 | 06:37 PM
Taterdog's Avatar
Taterdog
I think the roads in Texas are smoother and less abrasive than the rest of the US! &nbsp\\;&nbsp\\; Hope my do as well as yours. &nbsp\\;
