Cam Bearings/Oil pump Failures
Old Jul 28, 2008 | 04:15 PM
scnz's Avatar
scnz
Stage IV
Default Cam Bearings/Oil pump Failures
2006 Streetglide 103 = cam bearing, oil pump failure.&nbsp\\; Engine toast, HD and dealer warranty not honored.&nbsp\\; This SOP for HD?
Old Jul 28, 2008 | 04:17 PM
miacycles's Avatar
miacycles
Default RE: Cam Bearings/Oil pump Failures
Yes, more often than not. Aftermarket stuff is way better.
Old Jul 28, 2008 | 04:21 PM
rockdoc's Avatar
rockdoc
As soon as you do anything to the engine, the warranty is gone .... poof! My dealer 'said' they would stand behind my 103" because they installed it. My guess is that if my motor blows, they really will stand behind me and let me have it. Sorry to hear about your problems and hope they get fixed soon.
Old Jul 28, 2008 | 04:26 PM
TexasRedneck's Avatar
TexasRedneck
Have you contacted MoCo CS directly about it???
Old Jul 28, 2008 | 05:35 PM
scnz's Avatar
scnz
Stage IV
Called MoCo CS - S O L - if it left the factory as an 88, upgrade NOT covered by factory warranty, perhaps I should buy a Geezerglike aka GWing!
Old Jul 28, 2008 | 06:08 PM
blueflht's Avatar
blueflht
how many miles? wont the builder stand behind their work?
Old Jul 28, 2008 | 06:11 PM
dawg's Avatar
dawg
Lick your wounds and build a bigger engine with better parts.&nbsp\\; Don't give up on the bike
Old Jul 28, 2008 | 06:33 PM
TexasRedneck
That's something ah keep gettin' conflictin' stories on...if (for example) ya have the dealer install the MoCo 110" kit on a 96" motor, is it still covered by warranty or not?
Old Jul 28, 2008 | 06:48 PM
Weavr99FLHT's Avatar
Weavr99FLHT
My understanding was that if the upgrade was done at time of puchase, and all HD/SE parts used, then covered under warranty as long as still epa "legal".&nbsp\\; Anything done after purchase of the bike or not EPA legal, not covered under warranty.&nbsp\\; I could be wrong, I'm told daily I am.
Old Jul 28, 2008 | 07:29 PM
BadPiggy's Avatar
BadPiggy
You guys aren't very well informed on warranties.
A dealer can't void a warranty on say your cam bearings, because you changed radios.
Nor can he void the warranty on the radio because you changed cams.
Also, they have to PROVE that the part that took a crap, failed because another part you installed caused it.
The burden of proof lies with the manufacturer, not the consumer.
Any idea how hard it is to PROVE that say a cam plate took a crap because you changed pistons?
It's impossible!
On another note, were your cam bearings changed when you changed cams?
EVERY time you make a cam change, you change cam bearings.
&nbsp\\;
Simply put, your dealer is being a jackass...typical for dealers!
