Blown fuse
Old Jul 29, 2008 | 06:43 PM
hd2007's Avatar
hd2007
Default Blown fuse
I keep blowing the accessories fuse , I lose all the gauges in the faring , any ideas ? Wiring has not been disturbed. I took the bike to the dealer and they said they found nothing , on the way home blew it again .
Old Jul 29, 2008 | 08:16 PM
0204665J's Avatar
0204665J
Default RE: Blown fuse
Carefully check all wiring by your brackets in the fairing (a bad bracket). I had a bracket that chapped the wiring causing a ground.
Old Jul 30, 2008 | 07:39 PM
harleyrider_00's Avatar
harleyrider_00
&nbsp\\;My son had the front tire rubbing the wire that goes to the fender tip light. After he cut the wire and taped the end he never had another problem. You might check it.
Keep the faith
Harleyrider_00
Old Jul 30, 2008 | 08:18 PM
pandol34's Avatar
pandol34
You'll probably have to pull the console cover also.&nbsp\\; Do you know how to remove the ignition/key switch?
Old Jul 30, 2008 | 08:23 PM
EastSideBikerTrash's Avatar
EastSideBikerTrash
The blown accessory fuse is making the gauges quit working? This doesn't sound right.
Old Jul 30, 2008 | 08:25 PM
EastSideBikerTrash
I had a problem with my accessory fuse blowing but it didn't affect the guages. A wire inside the fairing was pinching on the frame when I turned the bike to the left.
Old Jul 30, 2008 | 08:35 PM
hd2007's Avatar
hd2007
Yes its the first fuse in the block , when blown none of the gauges work . I took it back to the dealer after work {pain in the a$$} I have less than a month left on the warranty , so hopefully they will fix it or I'll be messing with it myself.
&nbsp\\;
&nbsp\\;
&nbsp\\;
&nbsp\\;
&nbsp\\;
&nbsp\\;
&nbsp\\;
&nbsp\\;
&nbsp\\;
&nbsp\\;
&nbsp\\;
&nbsp\\;
&nbsp\\;
&nbsp\\;
ORIGINAL: EastSideBikerTrash
Old Jul 30, 2008 | 08:40 PM
pandol34's Avatar
pandol34
Keep us posted.
Old Jul 31, 2008 | 09:13 AM
dbuff's Avatar
dbuff
I don't know if the acc fuse is the same as the cig lighter fuse but I keep blowing that fuse and what was causing it was a metal piece off of a ceell phone charger came off and was stuck in the cig lighter and causing the fuse to blow.
Old Jul 31, 2008 | 10:28 AM
nemick's Avatar
nemick
If your wiring is anything like the Road King, I would have a good look inside the headlight housing. There are all manner of sharp edges to rub through wires in there.
