wheel chock
Old Aug 2, 2008 | 06:01 PM
patsac's Avatar
patsac
Default wheel chock
does a wheel chock need to be bolted down or can it be used without bolting it. reason i ask is that im going to be hauling my glide in a u-haul cargo van and im thinking that a chock wil help keep it upright . of coarse it will be also strapped .is a chock good insurance for hauling? and can i use one without bolting it down?
Old Aug 2, 2008 | 06:08 PM
FXSTDSE2's Avatar
FXSTDSE2
Default RE: wheel chock
Unless it has super wide legs, it isn't going to do much as in holding it up. I would wedge a short 4x4 in&nbsp\\;front of the&nbsp\\;front wheel to keep the fender&nbsp\\;from hitting,&nbsp\\;strap it down good but not from the handle bars. I have two peaces bolted together to keep it from rolling out from in front of the tire.
Old Aug 2, 2008 | 08:07 PM
HawgriderPa's Avatar
HawgriderPa
check out harbor freight.com&nbsp\\;&nbsp\\;
\\\\\\;- they have a&nbsp\\;\\\\\\; cross shaped chock.. $59&nbsp\\;&nbsp\\;ITEM 97841-3VGA
&nbsp\\;\\\\\\;
Heavy duty, fully adjustable wheel chock with an adjustable wheel locking system that can accommodate front or rear wheel sizes from 15" to 22" (80-127W).
supports the motorcycle in an upright position
[ul][*]Can be permanently mounted to the ground or bottom of a trailer[*]Two built-in tie-downs for added safety[*]Powder-coated 12 gauge plated steel base and wheel chock [/ul]
Overall dimensions: 36" L x 35-1/4" W x 16-1/8" H\\\\\\; Wheel plate dimensions: 5-1/8" L x 9-1/2" W x 15-1/8" H\\\\\\; Wheel support dimensions: 8-13/16" L x 7-7/8" W
Old Aug 2, 2008 | 08:11 PM
HawgriderPa
that chock doesn't have to be bolted down.. just wedged
Old Aug 2, 2008 | 08:12 PM
floridamk's Avatar
floridamk
Are you using one of those pingel wheel chocks or a condor type wheel chock? I dont think you will have any problems if using the condor as long as the bike is strapped but the pingel style I am not so sure. I used the condor in my trailer but I bolted the thing down.
Old Aug 3, 2008 | 05:12 AM
patsac's Avatar
patsac
ecir40
Sep 11, 2018 11:09 PM
Half-Fast Deuce
Wheels/Tires
May 30, 2011 06:50 AM
youngrider
Jul 1, 2010 12:55 PM
sbbrown
Mar 9, 2007 03:14 PM
