ohms 4 or 8?
Old Aug 4, 2008 | 02:57 PM
Bad Pig's Avatar
Bad Pig
Default RE: ohms 4 or 8?
damn forum! [:@]
Old Aug 4, 2008 | 02:58 PM
Bad Pig's Avatar
Bad Pig
guess i need to dig deeper
Old Aug 4, 2008 | 03:00 PM
Bad Pig's Avatar
Bad Pig
problem is, previous owner had these speakers wired in. radio plays good for a while then the speakers start cutting in and out?? aggrevating
Old Aug 4, 2008 | 03:18 PM
blueflht's Avatar
blueflht
02 uses 4 ohm speaker. look at the back of the speaker should be marked with&nbsp\\;wattage and ohms.&nbsp\\; it does sound as if you have a short in the wiring or possible ground issue. let me know if this helps
Old Aug 4, 2008 | 03:22 PM
Bad Pig's Avatar
Bad Pig
&nbsp\\;
&nbsp\\;
&nbsp\\;
ORIGINAL: blueflht
02 uses 4 ohm speaker. look at the back of the speaker should be marked with&nbsp\\;\\\\\\;wattage and ohms.&nbsp\\;\\\\\\; it does sound as if you have a short in the wiring or possible ground issue. let me know if this helps
&nbsp\\;
speakers are pioneer 4 ohm, can't remember the wattage. i'm sure they are crappy speakers. i just may put a whole new system in...just wanted to do other things first though.
Old Aug 4, 2008 | 03:27 PM
blueflht's Avatar
blueflht
factory harley radio in 02 is a good unit. you may want to research arc audio mini amp and some quality speakers. jl audio polk or infinitiy are all good starts
Old Aug 4, 2008 | 03:34 PM
Bad Pig's Avatar
Bad Pig
seems like it works ok for about 30 mins or so...
Old Aug 4, 2008 | 03:50 PM
Bad Pig's Avatar
Bad Pig
i can't even finish my response [:@]
Old Aug 4, 2008 | 04:16 PM
blueflht's Avatar
blueflht
amp may be overdriving speakers. but i would trace wiring first look for shorts
ninetyfivebravo's Avatar
ninetyfivebravo
I gave up.[:@]
