Belt drive issues
Old Aug 5, 2008 | 07:18 AM
Wassup8687's Avatar
Wassup8687
Default RE: Belt drive issues
If it is the pulleys too bad they wouldn't have caught it during the warranty.&nbsp\\;
Old Aug 5, 2008 | 10:24 AM
bagman1's Avatar
bagman1
Your saying it just snapped like it was cut? Thats a torque failure, probably to being too tight and a harsh torque applied as in a downshift possibly. Without seeing the wear pattern of the belt, if there were alignment issues there would be a pattern of abnormal wear. It would have to be pretty far out of alignment to be a concern as the belt will float on the front pulley.
Have any more info? That really sux, I feel for you. Thats a lot of work to replace a belt.
Old Aug 5, 2008 | 10:30 AM
Big Peter's Avatar
Big Peter
ORIGINAL: 1FLTRI4ME
I would think the problem would be with the pullies,alignment or adjustment.
&nbsp\\;
+1
Old Aug 5, 2008 | 01:27 PM
acedantinne's Avatar
acedantinne
This a question? stopped for hd on pa I 81 this sunday east bound lane belt problem. was that you? Was a glide.
Old Aug 5, 2008 | 01:53 PM
Calicruiser's Avatar
Calicruiser
Gotta be that the belt is too tight. Or the pully is out of alignment.
Old Aug 5, 2008 | 04:03 PM
TexasRedneck's Avatar
TexasRedneck
Yeah - a tight belt could cause it.
Old Aug 6, 2008 | 03:46 PM
bagman1's Avatar
bagman1
Default belt issues
Think of the two times the belt broke, look for commonalities. Were you two up, loaded to the max, hit a good bump?
Old Aug 6, 2008 | 09:07 PM
scarylarry99's Avatar
scarylarry99
Both times I was by myself no load downshifting and easy on it it seem to have a hard time going into second, then pop it went. Any way I had the first belt it had no wear on it and the was straight lined not like atear or anything.
Old Aug 7, 2008 | 12:54 AM
scarylarry99
I am considering replacing it myself. Any tips on special tools I might need?
Old Aug 7, 2008 | 07:33 AM
Hog Yild's Avatar
Hog Yild
I've never experienced this on a bike, but I do design machinery that uses timing belts.
The type of break you are describing, a sharp straight across cut is normally associated with the belt tooth riding up and onto the tooth of a pulley, instantly the belt loads multiply past the belt's strength and snaps the belt in two.
You are giving the belt a reversing load when you down shift, the wheel wants to continue moving forward and the belt wants to stop or slow down with the transmission.
A loose belt in this loading condition will cause what you are describing. Alignment may also be a problem, with the belt trying to ride up the flange of the rear pulley as it's trying to go the opposite direction (reversing load). Once it starts to ride up the flange, it slips a belt tooth onto a pulley tooth and snaps the belt as well.
I would start with making sure the belt is correctly tensioned and everything aligned.
