Originally Posted by FLHTim
Only 08's after December with new ecm. Tried rolling throttle foward but no luck mine was built in Sept and by the way fuel canister broke today had to be towed in
i have an 07 and had it done at the dealer for FREE. it has helped with the heat. but when you are sitting at a stop light and it kicks in, it sounds like its missing on one cylinder. kinda embarrassing to have other hear that. sounds like its outa tune. but worth it though
I have a build date of 3/08. I tried the to enable the heat management mode and was unable to do so. I am wondering if because I installed my own MAP from Latus I lost the ability to set the mode on/off with the throttle????
The EITMS feature can be enabled and disabled from within the SERT software as shown in the attached photo.
