Hog Tunes for '09 Street Glide
I'm another touring new comer...just wondering what my options are for upgrading the SG stereo. Will the upgraded speakers alone make a big difference, or do I need to add an amp as well? It was a little unclear to me from the Hog Tunes website if I can add an amp to the SG or not. It looked like the amps were only for the UC type setups. Thanks in advance.
I think the upgraded speakers help. It does not get a lot LOUDER, but they stay Clear when cranked up and don't distort as much. The amp is normally sold as part of the ultrasound setup, but I think Pez has sold it on its own before, BUT, if your gonna do that, you need to tell him, as he has two different ohm rated speakers, and the Amp needs the ones that normally come as part of the 4 speaker kit, not the ones that you would just connect to the stock stereo. FWIW, I DO think the amp improves even more on his front speakers.
If you just did the front speakers NOW, and want to add the amp later, you would have to change the speakers again to the correct ohm rated ones. Of course, if you just add the front speakers now, and later add the rear speakers and amp, THEN the front speakers move to the back pods, and you get new ones for the front that are compatible with the amp.
Or, if you add the amp and speakers to the front NOW, then add the rear pods later, you can re-use your stock speakers in the back, OR get upgraded ones from him for the back.
Does that make sense?
Call Pez, he's a great guy and will answer any of your questions.
before spending the big bucks for these mediocre setups give Firecap501 a hollar. he has arc audio setups available that will blow hogtunes or jm or hawg wired setups out of the water. arc audio amps are 1 of the cleanest sounding smallest in the fairing amps you cam buy. there are many posts on this subject, check em out
Most or all of the audible distortion is introduced by the head unit, and the only way to help this situation is to add a booster amp that provides a DB increase like the Hogtunes amp or replace the whole head unit with one that has higher output.
Even with the upgrades, the problem is that distortion still comes from the head unit as before, but the amp adds up to 3DB of overall output in addition to 10DB of extra bass. This means that at a given head-unit output you are getting more distortion-free sound output. I still hear distortion at times when it's really blasting, sometimes when just playing certain songs, but it is not as much of a problem.
I'm not sure what speaker-impedence is provided with the Ultrasound system of four speakers, as I don't run rears. I think the stock head unit drives 2Ω speakers in front while the amp drives two 5.75Ω speakers in the rear. This way the rear speakers don't over-power the fronts.
You can buy the 2Ω speakers now, then add the amp later, which is what I did. BTW, you can only order the amp alone directly from Pez, as it isn't a standard item, nor is it even on his website. When I bought mine about six months ago it cost $217 including shipping. Although I haven't heard other systems, I consider this money well-spent.
I believe the 2009's are 2ohm's. Do you have any info on the speakers or the cost for 2 speakers. So I can swap out the front stock ones. Do I haave to power these speakers with an external amp? How or where do I order them from? Is anyone in here using these speakers? I see alot of hogtunes and cycle sounds. But you think the arc are better and loudere with no distortion? What about water resistance? Thanks
It's more a matter of how much money you want to spend. IMO the speakers give you $100-worth of quality improvement, and the amp another $217 worth, and once you move upward you will become spoiled and won't want to go back. I can't speak for Hog Wired and other systems that cost much more since I haven't heard them, but they too may be worth every penny you spend. It's just a matter of how much money you want to let go of and how unhappy you are about the status quo.
