Xied
Old Aug 21, 2008 | 06:33 PM
troy.j's Avatar
troy.j
Default Xied
Ok, this is my first EFI bike. My new Ultra is setting in the states waiting for me. I have read a lot about the different fuel management systems out there. I am not looking for max power, just a bike that runs good and will last along time. I think I have decided on the Xied, but I want to do more research. I cant find anything by doing a Google search except for stuff on forums. Where do you get them, what would I search for?
EBay is out because the sight is blocked from out here.
Old Aug 21, 2008 | 06:57 PM
jcbpa's Avatar
jcbpa
Sorry can't be a help, but why not use the SE unit and have 1000's of guys all over the country be able to help. My SE works great.
Old Aug 21, 2008 | 07:09 PM
troy.j's Avatar
troy.j
Doesn't the SE keep the Fuel mix the same as stock? From what I understand the bikes are De-Tuned from the factory and run lean. Lean = Heat + early wear... All I want is to richen it up a little. From everything I have read the Xied is the most cost effective way of doing what I want to do. I am open to ideas and discussion. My mind isn't set on them yet. I just want to do more research on them. I want something I can install and remove easily with out needing dyno time or a day at the dealer or Indy shop. I do appricate your input, and invite more and others.
Old Aug 21, 2008 | 07:12 PM
waffler's Avatar
waffler
Do a search for nightrider they sell them also check the classified here there was a pair for sale for cheep. In the EFI section there is a lot of information If your just looking to cool the bike down a little these work really well. I had them on my 2007 while my thundermax was being repaired. Ness stage 1 w/a fatcat 2into1 I put 500 miles on and experienced no problems and my fuel mileage was avg 44-45
Old Aug 21, 2008 | 09:15 PM
Peculierboy's Avatar
Peculierboy
Steve's website is here http://www.nightrider.com/parts/
I have the xieds on my 08 and they work great, much cooler motor and more responsive all around.
Old Aug 21, 2008 | 11:34 PM
Intrepid175's Avatar
Intrepid175
Out of curiosity, which AF ratio version did you get? The web sites shows a couple of different versions. Thanks!
Old Aug 22, 2008 | 10:09 AM
roadking1893's Avatar
roadking1893
I have them on my 07 RKC for a year now. The best investment for your 07 and 08 96 engine, runs cooler and better throttle response. I got the EIED's AFR is 13.8.1 convert stock exhaust to true duals with K&N filter and get even better result. Since I've done that I seem to be able to rev up higher between gears without the engine sounding like it's working hard.
Old Aug 22, 2008 | 10:41 AM
honestbob's Avatar
honestbob
I went with the 02ied's they don't make it quite as rich and I left everything else stock. really made a big improvement in performance and temp. (cheaper too)
Old Aug 22, 2008 | 10:42 AM
clayguy's Avatar
clayguy
+1 on XIED. Work great, easy install.
Old Aug 22, 2008 | 11:06 AM
Peculierboy
As mentioned, the Xied's are richer than the IED's. The variable ones are not needed for the Touring bikes. This all the fuel management I have, and after alot of research, all I will put on this bike. Very, very happy. The wife even commented on how much cooler it ran, and asked me if I changed anything on the bike, so it IS noticible.
