Hogtunes
Old Aug 22, 2008 | 11:16 PM
cirhere2's Avatar
cirhere2
Default Hogtunes
Am I the only one that has problems with the hogtunes
Old Aug 22, 2008 | 11:29 PM
Bluesssman's Avatar
Bluesssman
I have not had any problems with their products. Why don't you give them a call...
Old Aug 22, 2008 | 11:37 PM
cirhere2's Avatar
cirhere2
Default hogtunes
thats the first thing i did do second was several e-mails He might be buzy tonight
just wanted to know if I was the only one
Russ
Old Aug 22, 2008 | 11:38 PM
Mr Zip's Avatar
Mr Zip
i know very little about hogtunes. I was thinking about getting the speakerpods for my tour pak with the amp. How good are they? Easy to install? I'm pretty handy with a wrench, but shy away from doing my own wiring.
Old Aug 23, 2008 | 06:56 AM
1badbagger's Avatar
1badbagger
Do a search for hogtune threads here. I never hear any bad about them. I have had their unit for 3 years, easy install, very helpfull and great sound. Even my service mgr. at the local Harley joint marvels at the sound from the set up. They blow away a stock Harley stereo.
Why don't you say what problem you're having ?
Old Aug 23, 2008 | 07:08 AM
Dustydog's Avatar
Dustydog
Yes! I just installed the 3 way for the Freeway system in my 08 Ultra Classic yesterday.
I'm getting nothing out of the left side of the amp.
I contacted Eastern Performance Cycles who I bought the system from and they refered to to the Hogtunes Website. Hogtunes has posted that they are at a trade show until Monday.
I'll call them on Monday and we'll see what they do.
It's a good thing I tested the system before I put the Batwing back together.
Old Aug 23, 2008 | 07:17 AM
StGlide07's Avatar
StGlide07
Default Hogtunes
Performed stock replacement for 07 Street glide.
Simple easy upgrade and install. Clarity much better than oem.
Search past forums for hogtune installation.
good luck.
Old Aug 23, 2008 | 07:33 AM
Hawgnuttz's Avatar
Hawgnuttz
I installed front and rear 2 weeks ago in mine. You dont have to be a wrench in my opinion to do this, unless you cant remove a few screws. I was skeptical about buying these over the OEM`s. I was like are they that much better than the OEM, well if you think your OEM speakers sound good then you`ll be in for a surprise if you install the HogTunes. I`m glad I made the switch and there was no wiring just Plug and Play. As for problems there are only 3 things I can think of, 1 is there is a difference in the front speakers and the back, make sure you put the front in the front and the back in the back. Whats the difference I dunno, but they are labeled front and Back. #2 - I guess you probably just got a bad pair of speakers,it does happen #3 If you had to do some wiring reasons unknown to me and you wired them up incorrectly. Mike
Old Aug 23, 2008 | 07:45 AM
cirhere2's Avatar
cirhere2
Default hogtunes
Can't get power to amp
started checking wire and on positive side to battery and the wire came loose at fuse
Old Aug 23, 2008 | 08:00 AM
badlandr's Avatar
badlandr
So is it working OK now?
Do you like the Amp?
Is it worth the $$?
I've been thinking about upgrading to it.
