Help needed
Old Sep 3, 2008 | 08:44 PM
hennyk's Avatar
hennyk
Question Help needed
I have a 07 EGC with Stage 1 screaming eagle slip ons. I am wanting to put on true duals. Been kicking around some ideas. Vance/hines headers with Arlen Ness Big Shot tuner. Does this sound ok? Any help will be greatly appreciated. Thanks.
Old Sep 3, 2008 | 08:50 PM
dawg's Avatar
dawg
How much money you wanna spend? That will play a role in advice. Also do you have a stage 1 air cleaner also or getting one?
Old Sep 3, 2008 | 08:58 PM
hennyk's Avatar
hennyk
Default RE
I already have the stage 1 air cleaner. Just want more torque and power for least amount of money.
Old Sep 3, 2008 | 09:05 PM
dawg's Avatar
dawg
You might want to look into a PCIII. You can get one pre-mapped from Jaime at FuelmotoUSA. All you have to do is tell him what you have for items and he will map it for you. You can also get a pretty decent package that includes PCIII, pipes, etc. from him as well. There are better tuners but they are a little pricey and there is nothing wrong with the PCIII
Old Sep 3, 2008 | 09:10 PM
hennyk's Avatar
hennyk
I have heard of that tuner. I also heard it erases the stock pcm memory and would void warranty. I am so confused over this I want to do the right thing. Do you know anything about the Arlen Ness bigshot?
Old Sep 3, 2008 | 09:15 PM
dawg's Avatar
dawg
Sorry, I don't know much about the AN tuner. A V&H Fuelpak would probably work well for you too.
Old Sep 3, 2008 | 09:18 PM
hennyk's Avatar
hennyk
Was told the fuel pak is junk.
Old Sep 3, 2008 | 09:21 PM
dawg's Avatar
dawg
I had a Fuelpak on my 04 and didn't have any problems with it, until I wanted to upgrade more and do a cam job. Then it wouldn't allow for any more upgrades past stage 1. Otherwise, it was a good unit for me. I also ran a PCIII on my 04 when I put in the cams and 95" engine. Now I run a SERT (race tuner)
Old Sep 3, 2008 | 09:29 PM
hennyk's Avatar
hennyk
I wouldnt mind a sert but the expense of dyno after installation. I have no plans to build my engine past a tuner and true duals.
Old Sep 3, 2008 | 09:58 PM
2011 Road Glide Ultra's Avatar
Then you can use a canned map on the SERT...........
