primary oils
Old Sep 4, 2008 | 12:34 PM
fmfire672's Avatar
fmfire672
Default primary oils
Ok I am new here and I have a question for you guys and gals, has any body used the ALLISON TRANS fluid in their primary yet? I am a diesel mechanic and have been around the allisons for a long time, when I switched them over to the Trans Synd they ran cooler and shifted better than ever.It is about $28.00 a gallon but I have plenty. Let me know what you think about it.
Old Sep 4, 2008 | 12:38 PM
skydoc's Avatar
skydoc
I run Dex/Merc ATF.
Old Sep 4, 2008 | 12:41 PM
bagman1's Avatar
bagman1
Im going to watch this thread. We use Transynd at the shop also, and I am a transit diesel mech (supervisor now). I recently changed my primary fluid and noticed it was hella hot, if I could only get it to cool down that would be sweet but the concern I have is clutch material and seal compatibility.
Where you located fmfire?
Old Sep 4, 2008 | 12:42 PM
hdelectra's Avatar
hdelectra
I run Amsoil 20/50
Old Sep 4, 2008 | 04:19 PM
mtairy biker's Avatar
mtairy biker
Originally Posted by hdelectra
I run Amsoil 20/50
same here amsoil 20-50 I have been thinking about ATF i will be watching this one for sure
I would think allison is a great product
Old Sep 4, 2008 | 06:27 PM
jag1886's Avatar
jag1886
I use Amsoil 20-50 in mine also. Why would you put something that off the wall in your bike????????
Old Sep 4, 2008 | 06:46 PM
Ultra61's Avatar
Ultra61
I use ATF...
Old Sep 4, 2008 | 06:56 PM
pandol34's Avatar
pandol34
Running B&M trick-shift & the shifting (no pun intended) has been smooth. However, it seems to run at about the same temp as the Syn3. Another 1000 miles and I'll be changing & evaluating. More to follow...
Old Sep 4, 2008 | 07:30 PM
robbie52's Avatar
robbie52
I run Castrol Transynd in my truck, but would not spend the extra bucks to use in wet clutch that works fine with 20W50 motor oil. $28.00 is a great price for Transynd, wish I could find it for that price.
Old Sep 7, 2008 | 10:20 AM
fmfire672's Avatar
fmfire672
I am located in Marion ,Ohio, I buy my trans synd by the drum from my local BP dealer.
