Garage Door Opener Button
Old Sep 10, 2008 | 06:41 AM
bdp's Avatar
bdp
Originally Posted by skydoc
Drilled hole in fairing to mount odometer switch.
I have two of those one for the house and one for the shop. House opener is 12v so I wired to the switched 12v on the bike. Shop is only 3v so had to leave the battery in.
Old Sep 10, 2008 | 06:55 AM
dannyotelco's Avatar
dannyotelco
Smile Garage Door Opener
I took my opener and soldered the contact so that it is always on. I then took the battery out and wired the positive and negative battery posts into the positive and negative leads on the high beam switch. This way I do not have to worry about a new battery. When you click the light on high beam power is sent to the remote and with the contact always on the door opener is activated. I always ride with low beams so it works great.
D
Old Sep 10, 2008 | 09:35 AM
hawg08's Avatar
hawg08
Originally Posted by Crusher
Here is my switch/button...
Is your button waterproof?
Old Sep 10, 2008 | 09:44 AM
hawg08's Avatar
hawg08
OK, I've finally decided what I'm gonna do: I'm gonna short across the contacts on the opener so I will be in to open mode all the time. Then I'm gonna solder leads to the battery contacts on the opener and splice them into the ACC button wires. Then I can open my door by switching the ACC switch off and on and won't have to mess with replacing the battery in the opener and won't have to have another button/switch anywhere. I don't use the ACC button for anything anyway so why not. Because it's switched power, it will only work when the ignition is on.
Old Sep 10, 2008 | 10:12 AM
04harleyboy's Avatar
04harleyboy
Just something to think about. Does Harley offer a normally open momentary closed switch that fits in the space? Then it would just be a push button operation. Just a thought......
Old Sep 10, 2008 | 10:40 AM
SgtThump's Avatar
SgtThump
Originally Posted by atexn4christ
Am I the only lazy one around here? I just velcroed a key fob sized opener to the dash.
I've got you beat. I get off the bike, type in the code on the pad outside of the garage, get on the bike, ride into the garage.
Old Sep 10, 2008 | 10:46 AM
rocknrod's Avatar
rocknrod
Nahh you need one of these on your dash
Old Sep 10, 2008 | 10:56 AM
jsimo7's Avatar
jsimo7
I bought the glove box door pouches from HD (29.95 part# 57400-06) and slip my GD opener in the right side and my Sat radio on the left side works good for me and there still room for my phone and other small misc. stuff. If I want to use the GD opener in another vehicle I grab it from the pouch. (not hard wired or attached to the bike) ride safe
Old Sep 10, 2008 | 06:12 PM
WWallstev's Avatar
WWallstev
5th Gear
Yes they make a momentary switch on the screaming eagle auto locks, I just bought one the part # is71764-07 I have not recieved it yet but should make it work ok.
Old Sep 10, 2008 | 06:29 PM
blueflht's Avatar
blueflht
tried to find that part # no results in hd catalog
