Bye-Bye wobble! Hello Bagger Brace! Pics!
If you have an older bike, like my 1990 FLHS, there are not many of these things available. I fitted a TrueTrack Tracula kit and it is brilliant! A Harley specialist who rode it recently reckons mine is the best handling dresser he has ever ridden. Not bad for an 18 year old bike!
On rubber-mount Harleys the rear wheel and swingarm are attached to the back of the gearbox. Buells and modern Sportsters have three stabilizer links, one at the cylinder heads, another in front of the engine, the other by the gearbox. The rubber mountings let the engine vibrate, while the links prevent the rear wheel moving sideways in the frame, such as when cornering.
Dressers have only two stabilizer links, one at the heads, the other in front of the engine. Dynas have only one link, at the heads. Softtails don't need stabilizers, as their engine is bolted in as god intended!
So these kits provide dressers with a third stabilizer. The improvements they give are worth the few bucks they cost and greatly improve handling. I have also fitted a kit to my wife's Dyna, with remarkable improvements.
I only have experience of TrueTrack. There is plenty of choice of brand, but what I will say is if you own a dresser, buy and fit one soon and don't look back!
I'm not sure that I have experienced the "wobble". Certainly haven't felt anything dangerous or scary. My everyday riding is a mix of side streets and freeway and lots of turning. I have felt instability at low speeds like turning into a gas station or slowing to enter an alley. If the brace would fix that then I'd sign up immediately.
I have done it to not one bike but two!
Our household now has three bikes, each with three stabilizers. There is no going back!
You all have the "bagger wobble" whether you want to believe it or not. It's inherent in the design. As I've said before "sit on your bike and shake the handlebars back and forth vigorously and you'll feel the lateral movement in the swingarm/motor". My bike no longer does this and I guarantee you'll notice the difference it makes under all speeds and conditions. Do a search and see if you can find any posts where someone has said it doesn't make a major improvement.....naw don't waste your time because you won't find one. I've spent more money than I care to admit to myself on my HD money pit (I quit counting after 6K) but the Bagger Brace was the best $300 I've spent.
Rick
I'm enjoying the time I spend on the forum since I have become a member. So much info from a whole bunch of wonderful and knowledgeable people. Great forum!! -Rick
