Warning About Stock Shift Linkage
Old Sep 13, 2008 | 07:38 PM
biz44's Avatar
biz44
It is funny that some bikes out there still have the stock rod on them and they have been there and working for years. A good riding bud of mine who beats the hell out of all his bikes is still using the stock unit on a 04' Fatboy....another is on a 03' Heritage with the OEM unit. ME....with my luck though.....I change them out about the same time I peel off the warning stickers and reflectors!
I aint sure, but I think it may have something to do with the way some people feel the need or just unconscious have the need to smack the shifter down into 1st gear when the light changes green or they are just pulling away from a stop. I swear sometimes I think I could hear it from 500 yards away. That big cerculnk.....that could be part of the reason for the high rate of failure...???
Old Sep 13, 2008 | 07:50 PM
russl179's Avatar
russl179
I do not do that with my bike. I never slam it into first gear. I pay attention not to lug the engine or shift at improper times.
Old Sep 13, 2008 | 07:57 PM
badlandr's Avatar
badlandr
Thanks for the tip!!
Old Sep 13, 2008 | 08:34 PM
flyingace's Avatar
flyingace
Originally Posted by Conehead
What exactly breaks the end where it attaches or the bar itself? What are most of you replacing it with?
Its the ball and socket joint. The (nylon) socket wears out, gets too big, and the ball end falls out.
Old Sep 13, 2008 | 09:06 PM
Conehead's Avatar
Conehead
Thanks flyingace, what did you replace it with?
Old Sep 13, 2008 | 10:42 PM
skratch's Avatar
skratch
here's my reply on another post:
Originally Posted by skratch
since no one answered you yet, i'll give you what i got. you will need:
2 ea heim joints 5/16-24 right hand (http://cgi.ebay.com/ebaymotors/ws/eB...m=280249330109)
2 ea 5/16-24 x 1 in hex cap screws (i used grade 5 stainless, not that much stress where you'll need grade 8, but you can if you want, but it costs more)
2 ea 5/16-24 jam nuts
1 ea 5/16-24 nylon lock nut
the bolt will thread into the lever on the transmission. but on the foot shift lever, the nylon lock nut holds the works together. all told, i spent less than 15.00 to do this. (i reused the stock linkage rod, but you can get a new spiffy one if you want. if you go that route, see if you can get one that is about 1/2 in shorter, that will give you more adjustment room)
2 ea
Old Sep 13, 2008 | 11:15 PM
nt6977's Avatar
nt6977
Wow had over 65000 on a 98 Ultra and never had a problem. You guys must have a very heavy foot. Just a thought.
Old Sep 14, 2008 | 07:37 AM
Ram's Avatar
Ram
Not only time to look at changing over to heim joints for shifting links but put the zerk fitting into the front of the case to lube the cross rod too....
https://www.hdforums.com/forum/primary-transmission-driveline-clutch/225838-grease-fitting-and-heim-joint-shift-linkage.html
Old Sep 14, 2008 | 07:52 AM
IAMSWUTIAMS's Avatar
IAMSWUTIAMS
Thanks Skratch, I ordered the heim joints
Old Sep 14, 2008 | 08:22 AM
vindyl's Avatar
vindyl
38,000 miles and still on the stock linkage And no problems at all. But since my bike is a 96 and I bought it used 96 might be a better linkage I know it is the original because I know the original owner so I asked if it was ever changed.
