Auto Compression release
Old Sep 17, 2008 | 07:13 PM
tgaetto's Avatar
tgaetto
Default Auto Compression release
Anyone out there added these to an 06? I'd like to do it if it is not to costly. I see the release list for 35ea not to bad but what about wiring harness?
I already have the manual ones but am a bit lazy with them
Old Sep 17, 2008 | 07:28 PM
sonic's Avatar
sonic
Gottem on mine but I don't know what they cost. I do know they are trouble free. What size motor do you have?
Old Sep 18, 2008 | 11:11 AM
tgaetto's Avatar
tgaetto
95" with HC pistons I also did a comp gear and since i have had a bit more hard start ups so I'd like to get the electronic releases...
Old Sep 18, 2008 | 04:52 PM
tgaetto's Avatar
tgaetto
Installation requires separate purchase of model specific ACR Wiring Harness P/N 70623-06 or 70623-08.
Will this harness work on an 06??
Old Sep 18, 2008 | 06:13 PM
Leftcoaster's Avatar
Leftcoaster
You should'nt need any compression releases at all - manual or electronic. Not on a 95" motor. I'm running 10.5/1, 577 cams on a 95" motor. No comp. releases and no starting problems whatsoever. The electronics can be problematic as evidenced on a friends '07 CVO. They would never close completely so his shop disabled them. He's had no starting problems either. Maybe check your battery to be sure it's 100%. Mine does crank 1-2 revolutions before firing.
Old Sep 18, 2008 | 08:15 PM
Biggzed's Avatar
Biggzed
Your bike may start fine without comp releases, but the question is how long will it continue to start?
Compression releases are just a smart investment. Whether you need them or not on every start up is not really the only criteria. It could mean the difference from getting your bike started when your battery unexpectedly goes a little low, and it will definitely make your starter last longer.
You can't make a blanket statement like 95" motors don't need them. Compression is the key, not necessarily engine size. Rmember that cam timing has a significant impact on cranking compression too.
Zach
Old Sep 18, 2008 | 09:06 PM
tgaetto's Avatar
tgaetto
Default Tune
I am going to change cams eventually so I may tune this out but I'd still like to go automated....
Thanks Z!
saltlick
Nov 13, 2017 11:16 PM
texashillcountry
EVO
17
Nov 24, 2014 04:22 PM
tx2lane1970
Aug 3, 2014 03:27 PM
steiniger
Sep 4, 2009 01:07 AM
HDF Tech
General Topics/Tech Tips
Dec 24, 2005 01:27 PM
