Power Commander
Old Sep 24, 2008 | 02:04 AM
brinks13081's Avatar
brinks13081
Default Power Commander
I hear a lot of folks on this website say that you have to set your trottle position when installing the PC. What exactly does that mean and how do you go about doing it? Sorry if thats a stupid question.
Old Sep 24, 2008 | 04:53 AM
jkoch09ultra's Avatar
jkoch09ultra
Hook you laptop to your bike and start it. Look at the RPM at an idle. If it says 0 on the throttle position at idle they you are good. Sometimes when you change to a new MAP it will change to a 5 or some other number. This will make it run poorly. Rarely happens and is easy to fix. Just check it. If it does not say 0 then follow the reset procedure. Procedure is easy. Then you are set.
Old Sep 24, 2008 | 09:39 AM
brinks13081
Okay, how do I reset it, my throttle % is 2 when its warm?
Old Sep 24, 2008 | 10:31 AM
TNTHarley's Avatar
TNTHarley
Call DynoJet. They do a nice job of walking you through it.
Old Sep 24, 2008 | 01:22 PM
EastSideBikerTrash's Avatar
EastSideBikerTrash
From the PCIII User Guide:
To reset the throttle position click on “Power
Commander Tools” and then select “Set
Throttle Position.
To reset both the closed and open throttle
positions, first make sure that the bike is
communicating to the computer, then click on
“Reset”. Twist the throttle wide open and
release. Now click OK.
To reset only the closed OR open positions
click on the arrows next to the respective
boxes and then click OK.
hth,
Dave
Old Sep 25, 2008 | 08:40 PM
Bryan1724's Avatar
Bryan1724
On the left side of this page PCIII USB Tutorials scroll down to #10 and watch the video. http://www.powercommander.com/powerc...downloads.aspx
Old Sep 25, 2008 | 09:18 PM
skratch's Avatar
skratch
while you're doing that, you may as well set the 100% as well. not as critical as the 0% throttle, but still helps nonetheless.
Old Sep 25, 2008 | 09:30 PM
Bryan1724's Avatar
Bryan1724
Yes, do both. What PI$$es me off about it this. They don't include any directions with the PCIII to tell people about the throttle position settings, I don't get it? My zero throttle position was at 6 before re-setting it. It throws your map all out of wack.
bmkbailey
Nov 22, 2012 09:07 AM
NstyJack
Jun 2, 2008 06:51 PM
bwr52678
Apr 8, 2008 09:05 PM
nada1
Mar 12, 2007 09:17 PM
bob53
Sep 21, 2006 11:51 PM
