Fork lock broken in locked position, more fun than should be allowed!
I head out of work this Friday afternoon looking forward to the ride home. I've had a couple of week streak where nearly every mechanical or electrical thing I've touched has broken in one manner or another. Nothing catastrophic, just nuisance, hard to fix, time consuming stuff. It didnt matter if it was personal property at home or equipment at work. It was one of those kinds of weeks where I'd have been farther ahead if I'd just stayed home. I didn't realize it was going to get a bit worse yet.
I unlock my 2006 FLHXi, snap it over to the usual position and attempt to yank the bars straight to fire up and ride. But the bars didn't move. I flicked the **** back and forth a dozen times and its just stuck. I wobble the forks a bit left right middle but no luck.
I call my wife up and describe the problem and tell her to google something like "Harley stuck fork lock" or such. She finds an article or two that makes it sound like if you smack the top of the ignition switch **** that a sticky fork lock pin just might pop loose. By now with a series of broken things in the last week or so I'm ticked off enough that I'm ready to try anything so I smack it with my hand a few times and it stays stuck. Im an engineer, Im fairly mechanically minded, I usually dont take out my frustration on a chunk of iron, but I guess I just had enough of it this week. I grabbed the biggest wrench out of the tool kit and wacked the ignition **** a time or two as well. All this accomplished was to bust the chrome **** key switch off the shaft that goes down into the ignition switch. I didn't think I hit it that hard, but anyway it broke. That prior advice about "Don't believe everything you read on the Internet" popped to mind. Meanwhile Im wondering how many hundred this is going to cost me to fix on top of whatever is wrong with the fork lock.
I call my wife back and have her grab my tool box out of the garage and head over to my work place. With the forks locked completely to the left, I'm looking at it trying to figure out what I might be able to take apart to figure out what's stuck so I can at least get the bike home. Anyway, let's just keep this part short and say there's not much you can get at with the fork locked to one side. I took a lot of things partially loose only to decide it wasnt going to work. There's at least one screw on the outer fairing you can't get off. I had a cigarette lighter type power adapter for my GPS plugged in, that helped a whole bunch too.
After about an hour of goofing around and I decide I'm defeated so I call the local dealer to see if they have any ideas. But no good ideas there, just a get the bike to us and we can work on it was about all they could offer. So I asked for some recommendations on anybody in town that could move a bike in this condition.
I start down the list. The first guy sounds helpful until I tell him I'm on the 4th floor of a parking garage. With the forks locked, he says he has to use one of his bigger trucks with a lift and there's no way its getting in a parking garage with a 7 foot ceiling.
Its starting to dawn on me that Murphy has been riding shotgun with me for several weeks and isn't about to give it a rest on this Friday afternoon.
Now its late, my wifes hungry, weve missed an evening event we were supposed to attend, etc. We leave the FLHX behind and head home. About ˝ way home it strikes me that Ive got a service manual that a riding buddy gave me a while back when he traded up to a newer bike. I scan a few pages and I see that you are supposed to access the key switch mechanism from the inner fairing side. But the book talks about only being able to do this with the forks moving freely. Now that Ive seen a picture, I have a brief visualization of drilling the fork lock pin out from the bottom, but quickly decide with my luck my drill would probably light off the gas tank and Id have to buy a new parking garage too.
Having at least identified my target with the service manual, I throw about every tool box Ive got in the car and head back to the parking garage. After a bit of checking, though I cant see it, I do discover that you can get a Torx driver on the left side fairing cap screw. You probably cant see it (might have had something to do in that the spot I was in at the parking garage was about as far away from any light as you could get in the facility), but you can get it out. Within about 10 minutes Ive got the fairing cap off, l pulled the ignition switch assembly out and I can move the forks again! With my new found knowledge I expect if I had the right tools in my pocket I could get at a 2006 touring model unfork locked in 2 or 3 minutes. Its not that hard. (well, maybe it is, it took me 5 hours to get to this point)
I dont quite understand how the fork lock is supposed to work, but I ended up with a loose .5 round 1.25 long pin out of the bottom of the ignition switch assembly, its tapered on one end, has a rim on the other, from a few feet away youd think it was a flat nosed 45 caliber shell.
So no fork lock for now. Ive got a 10 inch locking pliers in place for an ignition key swtich ****. I cant lock it, but I can pull the shaft out of the switch so that you cant turn it on electrically. Im kind of wondering if I need to spend any money on it now...?
I spotted an Internet article about a Harley service bulletin stating that there was a problem with a weak part in the fork lock of the 2006 touring bikes. Im going to follow-up on that one a bit more. I dont want to do this again.
For a 2006 touring bike owner, this should be something that ought to be fixed before it breaks.
Good luck.
Mike
It makes a fair war story, but I was sured ticked off the night it happened...
