Muffler rubber mount fix
Old Mar 28, 2006 | 11:58 PM
SteveO's Avatar
SteveO
Default Muffler rubber mount fix
The muffler rubber mounts in the rear wear out, and dry out very quickly due to the heat, they become loose, hard, rattle and squeak.
I discovered a quick fix. First the mufflers must slide within the rubber mount. They move with the engine torque. Do not tie them down or prevent them from moving or something else will break within the exhaust system.
Remove the two small bolts and slide out the bracket on the rear of the muffler under the bag mounts. Lubricate the rubber bushing with silicone inside top and bottom along with the bracket you just removed. Reinstall the bracket upside down (you will need to force in) and line up the bolt holes. Snug down the bolts, be sure to use blue loctite. Rattle and looseness stopped, and the muffler can still move with the engine. Clean any excess silicone spray off the mufflers with acitone or mineral spirits. Keep the silicone off the floor !!! Put news paper under your work area. Trust me on this one.
Steve
Old Mar 29, 2006 | 12:16 AM
SubZer0's Avatar
SubZer0
Default RE: Muffler rubber mount fix
Maybe we should add this to the do it your self section?
Old Mar 29, 2006 | 12:26 PM
billnourse's Avatar
billnourse
Steve,
I have found that a little brake fluid on the rubber mount also works well. Brake fluid will treat, lubricate, and restore the rubber without causing deterioation. I have a small oil can that I keep full of brake fluid and at every service I give the rubber mounts a little shot.
Regards,
Bill
Old Jun 7, 2010 | 08:18 AM
Geezer_Glide's Avatar
Geezer_Glide
5th Gear
Wink Trying to save $4.00 ?
It's easier to solve this correctly. If you've gone to the trouble to take off the muffler mount, just REPLACE the rubber bushings, rather than jerry-rig the assembly. These things cost $2.00 each, and are the ONLY things H-D sells that cost under a left nut.
Old Jul 6, 2010 | 04:07 PM
StreetGlider57's Avatar
StreetGlider57
I'm bringing this thread to the top. I've been having this rattling problem myself shortly after the bike warms up. Now I know it's the muffler mount. Anyone have a Harley part number for the rubber mount?
Old Jul 6, 2010 | 04:39 PM
boom23's Avatar
boom23
From the 2009 Touring Parts Catalog: 65724-85.
Old Jul 6, 2010 | 06:43 PM
SciFiGuy's Avatar
SciFiGuy
Not necessarily, Had a similar rattle when I was running the Rush slip-on's with the 2" baffles. Turns out it was the baffle itself rattling inside the left side muffler.
After emailing Jamie at FuelMoto who advised me to removed the baffle and tapered the end of it to make it fit a little more snug inside the muffler. After I did this the rattle was gone.
So if you change out the rubber mounts and still have the rattle you might want to give it a try.
Old Jul 6, 2010 | 06:56 PM
hougz79's Avatar
hougz79
Anyone try these?
http://www.kundratickustoms.com/merc...asp?prod_id=43
Old Jul 6, 2010 | 06:58 PM
upstate tim's Avatar
upstate tim
I thought my baffle was rattling too. Took off the saddlebags and grabbed to mufflers one at a time wearing a leather glove. Thought maybe the rubber mount might be the culprit, thought it was a longshot but disassembled the mount/plate. Used vasaline so it would not eat the rubber and sure as hell the rattle is gone. seems strange anything made of rubber casuing a rattle noise
Old Jul 6, 2010 | 07:49 PM
cmcsns's Avatar
cmcsns
From: Beverly Hills, Fl. Swimmin pools. Movie stars
Just give it a squirt of WD40. End of problem.
