injector cleaner
Old Oct 1, 2008 | 11:51 AM
bgano's Avatar
bgano
6th Gear
Default injector cleaner
2005 RK with 15K miles. Anyone have any suggestions for a good injector cleaner? Does the product really make a difference? Suspect I fouled something up with multiple bad gas stops on the way to and from Sturgis. Periodic rattling can noise right side of bike down by the cam chain cover when stopped and the rpms seem to drop off.
Old Oct 1, 2008 | 12:02 PM
Leftcoaster's Avatar
Leftcoaster
Suggest Seafoam for the injectors but more importantly you should check the cam chain tensioners ASAP !!! Metal to metal noises cost big bucks.
mariner227's Avatar
mariner227
I'd be suprised if your problem is fuel related. The first thing to check would be the cam chain tensioner pads. This is a common problem on pre 07 twin cams. Your mileage is a bit low for this but who knows.
For an injector cleaner I use Seafoam. It's also a fuel stabilizer.
Old Oct 1, 2008 | 12:14 PM
Wassup8687's Avatar
Wassup8687
Seafoam is good stuff. I slap a can in the truck every now and then to keep it clean.
Two Lane Tramp
2014-2024 Touring Models
19
Jan 24, 2018 08:59 AM
oldhippie
Mar 7, 2015 05:18 PM
hawkmaneg
Jul 16, 2009 10:57 AM
OneBlackFly
Jan 26, 2008 07:28 PM
rezrider
Jul 6, 2006 08:39 PM
