Lower End rattle when not under load
Old Jul 16, 2009 | 01:01 AM
hawkmaneg's Avatar
hawkmaneg
Default Lower End rattle when not under load
I have a 99 flht with 82000 miles it has just started making a rattle noise on the lower end when I am not under load. When cruising at lower rpm around 2000-2800 it rattles at 3000 it doesnt. I just had another 10000 service and all was good except this new problem and I wonder if this could be a cam issue or a rod bearing . I am unsure of the cam set up since the bike had 20000 miles when I bought it and I have maintained it. has anyone had the same problem ? I dont want to quit riding untill the winter and all else runs great .
Old Jul 16, 2009 | 01:18 AM
bikergeoff's Avatar
bikergeoff
Pull the cam cover and get a look at those cam chain tensioners. They make quite a bit of noise when they go. You don't want your oil pump eating all that nylon and circulating it thru the motor. If the tensioners are ok, I'd let a shop have a look, unless you feel comfortable opening up the engine.
Old Jul 16, 2009 | 03:10 AM
emwolb's Avatar
emwolb
geoff is right, check those cam chain tensioners, at that mileage they're bound to need replacing. might also want to check your primary chain tensioner as well. that may also need replacing, and if so there is an easy fix that works great. it's the newer style that you don't have to adjust, it's self adjusting. if you have to do the cam chain tensioners there are three basic ways you can go.. first is go with stock early twin cam tensioners. not advised. second would be the improved new style chain and tensioners, and third being gear drive cams. those are the available options that i can think of. lots of miles on those cam chain tentsioners, and bound to be worn down to nothing.
Old Jul 16, 2009 | 09:06 AM
hawkmaneg's Avatar
hawkmaneg
Thanks for the advice , I will check those tensioners out. Sounds like i dont want to ride if they are going out and if I am lucky enough for that to be the problem a failrly easy fix.
Old Jul 16, 2009 | 09:10 AM
BoomerBob's Avatar
BoomerBob
If the tensioners aren't it then maybe it's a loose exhaust pipe or shield.
Old Jul 16, 2009 | 10:57 AM
Underdoggie's Avatar
Underdoggie
1st Gear
I had a noise like that and it turned out to be sheared off stator bolts. The stator was just floating around in there. Not a real common problem, I only know of one other over the years and that was on an old shovelhead flh.
Two Lane Tramp
2014-2024 Touring Models
19
Jan 24, 2018 08:59 AM
tut60
Exhaust System Topics
24
Sep 9, 2009 03:23 PM
Professor
May 27, 2007 01:22 PM
rezrider
Jul 6, 2006 08:39 PM
highwayking
May 15, 2006 03:55 AM
