Greasin the neck on a Bagger
Old Oct 16, 2008 | 01:58 PM
cardboard's Avatar
cardboard
Default Greasin the neck on a Bagger
Don't know if anybody is interested in this but here goes.
Got over 19,000 on my FLHT and its a year old this month.
Went to put a set of plugs in my bike and couldn't find any feeler guages. Was gonna grease the neck and couldn't git the grease gun on the fittin. So I took it out to take with me.
So I busted out to NAPA 10 miles away. Went in and got a set of feeler guages.
Showed the man the fittin I took out of the neck and said I want a 90* fittin.
He gave me one. so I come home to the pad to put it in.
After turnin it a couple times it hit the neck and I couldn't git it to go in. So I picked up my trusty bifocals and got to lookin at the fittin. It has a hex head on the end to screw it in and it had a hex fittin on the 90* angle also.
So I got a 1/4 drive metric socket and went to the vice and put the big end in and clamped it in the vice and put the socket on the fittin end and unscrewed the 90* out.
Then I went to the neck on the bike and screwed the end into the neck,
I got a metric socket to go on the small end and got a nut driver that would fit it and put some blue locktight on it and screwed the nipple intothe fittin and got my grease gun and greased the neck with ease.
So if anybody is trying to grease the neck on a bagger and struggling this might help you out of a bind
Old Oct 16, 2008 | 02:01 PM
Tinkermc's Avatar
Tinkermc
I bought a 45 degree for mine and use synthetic grease, have been very happy
Old Oct 16, 2008 | 02:02 PM
n8dc's Avatar
n8dc
Just did the same thing last weekend but i had the fitting in my parts drawer...
Dave
Old Oct 16, 2008 | 02:11 PM
EasternSP's Avatar
EasternSP
If you used regular grease, you're going to find it oozing out over the next decade adn getting all over everything from the steering head to your tail light.
If you use the high temperature grease, it will stay in the steering head.
Old Oct 16, 2008 | 02:42 PM
88b's Avatar
88b
on my 06 FLHT I just took off the chrome trim under the passing lamps ( 4 torx bolts ) and got on the stock fitting. must have taken me 5 minutes.
Old Oct 16, 2008 | 03:57 PM
IAMSWUTIAMS's Avatar
IAMSWUTIAMS
I didn't have a problem with it, just turned the wheel to the left.
Old Oct 16, 2008 | 04:22 PM
harley-jones's Avatar
harley-jones
I put in a 45degree.
Then took the straight one I remove from the neck and put it in the cross shaft of the shifter linkage.
Got the idea from one of Dawg's post.
galaxyfe
Jun 24, 2015 01:25 PM
galaxyfe
Jun 17, 2015 06:58 PM
galaxyfe
May 26, 2015 08:48 PM
ajay450
Mar 12, 2009 08:43 AM
THABULL
Jun 29, 2007 10:22 PM
