Fork oil Question
Old Oct 18, 2008 | 11:59 AM
StreetKing's Avatar
StreetKing
Default Fork oil Question
I'm dropping my 08 RK -1in- with the HD lowering kit and was wondering if I should use the Screaming eagle fork oil. Will this help the ride and less bottoming out? TIA
Old Oct 18, 2008 | 02:22 PM
BadPiggy's Avatar
BadPiggy
Search the forum. Most of these guys like the SE Heavy Duty fork oil.
I use Bel-Ray 20w, myself. No particular reason that I use this brand over the SE other than I try to support my Indy shop.
Should make your scoot a better ride.
Now would be the time to add chrome/black/color of your choice lowers & cowbells.
Have fun on the install. Not a hard mod. Don't scratch anything!
Old Oct 18, 2008 | 04:52 PM
cegusa's Avatar
cegusa
I would recommend the HD Screamin' Eagle heavy duty. Not the race version. It will give it a nice firm feel without creating any jarring effect.
Old Oct 18, 2008 | 05:04 PM
iclick's Avatar
iclick
Yes, I just changed my fork oil and replaced it with SE Heavy (#99881-87). I would say it is a definite improvement with no downside except a slightly firmer ride--not harsh, just firmer. Dive and bottoming are both better-controlled, and since doing the change I haven't had any bottoming at all.
HD also makes an SE Extra Heavy fork oil (Racing), but although I haven't tried it I don't think you'd gain anything by using it, and the downside would be an even firmer ride. Control is very good with the SE Heavy.
For any of you with late-model FLH's who want to change the oil quickly and easily without removing and disassembling the forks, check out the link below. This thread started out as a query about doing this and by page 5 I decided I'd go ahead and try it myself. It worked better than expected and took about an hour for both forks.
Fork-oil-change Tread
Old Oct 18, 2008 | 11:34 PM
blueflht's Avatar
blueflht
+1 on iclicks post. i use the s/e heavy in my front and 10 wt synthetic in the rear . much firmer ride without the sloppy bottoming habits!
Old Oct 19, 2008 | 07:40 AM
StreetKing's Avatar
StreetKing
Thanks for the info guys. iclick did you go with the shorter air shocks(street glide) or a progressive style rear shock. I ride 80% solo and 20% two up. TIA
av ultra
Feb 3, 2012 09:24 AM
soos
Feb 18, 2011 02:31 PM
Kevinm40
Aug 20, 2010 08:22 AM
Joshman
Sep 17, 2009 08:58 AM
tenacean
Dec 29, 2008 06:05 PM
