fatcat install instructions?
Old Oct 21, 2008 | 12:16 PM
leohd's Avatar
leohd
Default fatcat install instructions?
does any one have the instructions to install the fatcat on a bagger? I also have the falsie? wondering what hardware they supply and what I use from the stock exhaust? if you could email me them it would be appreciated. Thanks
Old Oct 21, 2008 | 05:10 PM
maineultraclassic's Avatar
maineultraclassic
You don't use anything from the stock exhaust, except for the rear hangers under the saddlebags.
Steve
Old Oct 21, 2008 | 05:18 PM
Wally's Avatar
Wally
PhilM let me in on a little trick when I did mine.
Before you remove the transmission end cover, park the bike on a 2 x 6 so it tilts further to the left and you don't loose any transmission oil.
Having a friend on that side of the bike is a good idea too.
Old Oct 21, 2008 | 05:52 PM
leohd's Avatar
leohd
as far as stock brackets, D&D said the fake header pipe for the falsie mounts to the stock starter bracket and also some people use the stock bracket by the trans cover some use the black one supplied(which I do not have) since I bought used from a forum member. why would I have to remove the trans side cover?
Old Oct 21, 2008 | 06:52 PM
Wally's Avatar
Wally
There is a bracket that holds the Fatcat on that attaches in there and you need to remove the end cover to do it.
If memory serves me, you also need to remove the stock bracket while you're are there.
P.M. PhilM for details, he's done lots, I've only done one, and it was a while back.
jorswift
Mar 31, 2010 08:30 AM
ncbeast
Nov 3, 2009 05:01 PM
rockon
Dec 11, 2008 07:08 AM
avcaruso
Feb 8, 2008 09:56 PM
RPMC312
Exhaust System Topics
May 30, 2007 12:01 AM
