2007 flht hp???
Old Oct 22, 2008 | 08:41 AM
superstandardFL's Avatar
superstandardFL
6th Gear
Default 2007 flht hp???
ok guys new to the forums here just wondering on HP. i did some checking throught the posts on the subject but never found anythign with my set up . i have 103 ci, 255 cams screamin eagle breather, true dual rhinehardts with sreamin eagle dealer download to match the motor kit. any ideas where i would be sitting HP and torque wise? also what should i do next? head work? of fuel pack of some sort? dropping to teeth on front drive today for more bottom what do you think whats next? thanks in advance for the info
Old Oct 22, 2008 | 11:57 AM
Harleypingman's Avatar
Harleypingman
If you go to HD's website, you can find dyno charts for your 103" Stage II Big Bore Kit. The dyno charts are in the SE Parts Catalog. Just scroll though the PDF files to find your build.
http://www.harley-davidson.com/wcm/C...p?locale=en_US
With the Rineharts, you probably make a few more HP, and probably slightly less torque at lower rpms.
As for changes, the lower gearing may be enough for you, at least for a while, since it should add a noticeable amount of torque at the rear wheel at lower rpms than the OEM comp sprocket.
As for what's next, figure out what you want for how you ride, and talk to reputable engine component vendors, e.g. Head-Quarters, GMR, etc. Much better to do cams, headwork, and perhaps pistons as a package to fit the way you ride and what you want.
Old Oct 22, 2008 | 12:11 PM
llmotorcycles's Avatar
llmotorcycles
that should be a real 100 Hp 100 tq setup
Old Oct 23, 2008 | 01:23 AM
Comfortably Numb's Avatar
Comfortably Numb
Default ....
...Not enough. I'd be VERY surprised to see triple digit HP, especially running the MOCO's download. (still too lean) TQ might be in there though, maybe.
CN
Old Oct 23, 2008 | 01:26 AM
Comfortably Numb
Default ....
Highly doubt it.
CN
Old Oct 23, 2008 | 05:53 PM
jag1886's Avatar
jag1886
If you spent all that money on that stuff you should have also gotten a Race Tuner and then you would know how much HP you have.
It's rediculse to do a down load after doing all that work.
Spend a few more bucks on a Race Tuner and a dyno tune. Another added benefit of the Race Tuner upgrade is you will be all set up for farther improvements down the road also.
elky72ss454
Milwaukee Eight (M8)
Jan 6, 2017 08:03 PM
KWC6
Jan 6, 2013 05:34 PM
Kennyboy62
Sep 8, 2012 06:32 AM
gliderider04
Mar 23, 2011 05:48 PM
C-Man
Jun 14, 2010 08:18 PM
