reduce compression
Old Oct 24, 2008 | 10:01 PM
gpp's Avatar
gpp
Default reduce compression
i have a set of se heads for my 103 build that yeild about 10.80 compression according to the harley chart.how can i get it down to about 10.01?
Old Oct 25, 2008 | 07:45 AM
maineultraclassic's Avatar
maineultraclassic
There is no way to know for sure what your CR will be until you measure your deck height and have the combustion chamber measured, and what head gasket you are going to use. That, and only that will tell you what your CR will be when the motor is assembled.
You can't go by some Harley chart as the chambers of the heads are always different, and your deck height could be positive or negative.
Steve
Big_O
Engine Mechanical Topics
45
Jan 21, 2023 05:41 PM
tonebone_79
May 19, 2017 05:07 AM
lt1tyrell
Exhaust System Topics
Aug 22, 2011 10:00 PM
Rebel78
Dec 19, 2008 03:41 PM
gpp
Nov 7, 2007 08:27 AM
