Auxiliary Light For Road Glide
$150 for HID's. you won't need auxiliary lighting with these.
Also, is there a thread on all this I can read?
Thanks for the help.
Steve
http://www.cvoharley.com/smf/index.php?topic=20543.0
Us Road Glide guys would use the two light car kit.
An exerpt from that thread.
A quick trip around the block had me wondering why I hadn't looked into this sooner. The speed limit signs glowed to the point where it looks like someone is shining a light at me. The distance that the lights shine is farther than I can see clearly and for that matter farther than I should be looking while riding. The low beams are fantastic as they illuminate a very wide pattern but not so far out that I'd be blinding other bikes following them. I believe some of this is due to the Euro reflector.
As for the light color. I went with the 6000K which is called pure white. It is so white that it appears to have a slight blue tint to it, sort of like ice. While this does not bother me I'd be curious what the 5000k or 5500k looks like.
For me this one of those mods I'll do immediately when I purchase a new bike. The beater bike is next as a candle is brighter than that headlight!
http://www.xenonlink.com/product_inf...products_id=89
H4/9003 6000K Bi-xenon HID-Xenon Auto Kit The H4/9003 Bi-Xenon bulbs in the bi-xenon kit stay fixed and there is a shield that covers and uncovers the capsule of the xenon bulb as you switch from low to high beam, thus changing the beam pattern. The high beam gives an upward projection and the low beam gives a forward projection. You will maintain the same beam pattern with dramatic increase in intensity and distance.
Available Color temperature:
5000K, 6000K, 8000K, 10000K.
Items in the kit :
* 2 x HID Bulbs
* 2 x Ballasts with Secure Mounting Brackets
* 2 x Wire harness
* 4 x Zip ties
* All necessary wires and install accessories
* Installation diagram(English)
Product Features:
Brand New TRUE HID (High Intensity Discharge) Xenon Conversion Kit
5000K~10000K HID Bulb emits Cool light beam color
Convert your dim yellowish halogen lights to the Brightest HID lights
Direct Plug & Play Installation
Requires NO MODIFICATION to factory light housing of your vehicle
Costs $1500+ at your auto dealers
Kit include EVERYTHING you need to convert to HID: HID Bulbs, Ballasts & Wiring Harness
100% satisfaction guaranteed. One Year Warranty for all parts.
Genuine high quality products
100% Water & Weather Proof
Retrofit bulb types: H1, H3, H4 (High & Low), H7, H8, H10, H11, H13, 9004, 9005, 9006 & 9007, 9008, 9145, 880, 881.
3X Brighter than halogen lights for greater night-time driving visibility
10X Longer Lasting. No need to replace for life of the vehicle potentially
100% Reversible to your original factory halogen headlight
35% less power consumption
Generate less heat
Highest Industry Standard quality products
Extra long wiring harness for easy installation
World's best quality ballast modules
Note: The Kit does not include igniters because they are integrated into the ballasts. Some lower quality kits come with separate igniters, but come with more complications as a result.
What ever you do and no matter who you buy them from, there is no substute for great lighting. The absolute best by 3 times is HID. Look for many many posts (example) from members on this subject.
Go here for what HID (HDF member heywood727 photobucket) looks like on your Road Glide. For your lighting needs
PS the quote by the manufacturer "Note: The Kit does not include igniters because they are integrated into the ballasts. Some lower quality kits come with separate igniters, but come with more complications as a result." is pure BS. The reason why these kits can be sold cheaper is because the cost way less to purchase. The ballasts pictured are 3 year old technology and are mechanical. That is why they are so large. I know what they cost as I have to make the choice to buy what type and brand.
Ride safe
http://www.*****************/gallery/d...022081352b.jpg
