HD Fog Lights
Old Nov 11, 2008 | 07:17 PM
russl179's Avatar
russl179
Default HD Fog Lights
Is there an easy way to install them so that they run with the driving light on? Can I install them to run separately of the other lights?
Old Nov 11, 2008 | 07:22 PM
Bluesssman's Avatar
Bluesssman
Sure, just wire them through a separate switch and make sure you use a relay.
Old Nov 11, 2008 | 07:42 PM
johnnyhonda's Avatar
johnnyhonda
I have aux driving lights on a separate switch so that I can run them with hi or low beam. Check out www.easternbeaver.com. I got my aux fuse box and wiring harnesses from him. Jim will custom make a wiring harness with a waterproof LED switch if you like. His products are top quality and his service is second to none. An aux light wiring harness will run you around $50 or so with shipping. It's worth every penny. It's just "plug 'n play" with one of his harnesses. His shipping from Japan to my home in Charlotte normally takes less than a week!
Spartaman
Apr 25, 2017 02:01 PM
wagsrk08
Feb 4, 2014 11:22 AM
cmosentine
Aug 19, 2012 12:09 PM
Jukebox
Feb 19, 2009 06:20 PM
jarman
Nov 2, 2007 09:50 AM
