PSI in your shocks
Old Apr 6, 2006 | 03:51 PM
wildwill's Avatar
wildwill
Default RE: PSI in your shocks
ORIGINAL: Reddawg
oil in the air line is comming from your air compressor. not your bike.
DO NOT, I REPEAT...DO NOT EVER USE AN AIR COMPRESSOR ON HD AIR SHOCKS.
They put out entirely too much air pressure and will blow the shock. Get the HD hand pump made specifically for this purpose or use a bicycle hand pump.
Old Apr 6, 2006 | 04:04 PM
QT Hush's Avatar
QT Hush
ORIGINAL: Reddawg
Actually, I have never used my air compressor to put air in the shocks. When I checked pressure, oil came out, no air. So no, it is not coming from my air compressor.
Old Apr 6, 2006 | 04:07 PM
Kahuna's Avatar
Kahuna
Reddawg,
There is oil inside the shocks, and not from the compressor. You shouldn't be using a compressor to fill your shocks anyway. Unless you're itching to buy a new pair every time you fill the air! An hand airpump is a must for every bagger's owner with air shocks.
ORIGINAL: Reddawg
Old Apr 6, 2006 | 04:54 PM
Reddawg's Avatar
Reddawg
granted I would not suggest every joe to us a compressor on their air shocks. I have a small oilless air comprssor with an air regulator set to 20 psi, I have adjusted my shocks up & down many times with no problems. The guy with straight oil in his lines obviously has problems with his shocks.
Old Apr 7, 2006 | 03:44 AM
harleyboy63401's Avatar
harleyboy63401
I run about 8 lbs. in mine for solo and about 12 when loaded down for a trip. Oil in the shocks is normal.
Old Apr 7, 2006 | 03:54 AM
Tripper's Avatar
Tripper
10 psi for single and 2-up. I bottom out once in a great while 2-up. Harley hand pump is worth every penny.
Old Aug 18, 2007 | 06:38 PM
UltraDuke's Avatar
UltraDuke
got pump today, was bottoming out 2 up, turns out there was only 5psi from the dealer, upped it to 15, better ride all around. that tool is worth it.
Old Aug 18, 2007 | 06:57 PM
CSI's Avatar
CSI
10 lbs solo, 15 two up.
Old May 5, 2008 | 09:01 AM
SgtThump's Avatar
SgtThump
What about those little car air compressors? The ones that are powered from the cigarette lighter? Those things seem super weak anyway. Would that be okay wiht air shocks as long as I kept a real good eye on what's going on?
Old May 5, 2008 | 10:20 AM
atrox88's Avatar
atrox88
I usually run 15psi with my fat a$$ on it. 60 when my wife rides
