stock exhaust question
Old Apr 7, 2006 | 06:20 PM
TowJam's Avatar
TowJam
Default stock exhaust question
Apologies in advance if this is a stupid question, but it's been gnawing at me... Since each cylinder on a TC88 has its own exhaust pipe, why is there a crossover? By having this crossover, I'm assuming that the majority of exhaust will come out the right-side pipe. Is this correct? Why oh why?
Old Apr 7, 2006 | 06:25 PM
bountyhunter's Avatar
bountyhunter
Default RE: stock exhaust question
It don't matter why, stock pipes just SUCK! Cut em' off, toss em' out and put on a rockin' set of duals. You and your bike will both be a lot happier, guaranteed. Nice RG.
Old Apr 7, 2006 | 06:32 PM
100thRK's Avatar
100thRK
Quote"A crossover pipe increases bottom end (read torque) significantly, and it does so without sacrificing horsepower. The stock Harley bagger setup takes advantage of this well known property of the law of physics." Unquote
Saw a post awhile back and this was the response.
I am just the messenger. Though I do run stock pipes with SEII mufflers. Tried Rhinehart slipons, Rhinehart true duels and the SEII's. Best tq/hp curve was with the SEII's. Dynoed bike and Tq/hp cross at 100. Others make more hp but overall the SEII provided the curve my tuner was looking for. Everybody has a opinion on this and each bike is different.
Old Apr 7, 2006 | 07:40 PM
RBJones's Avatar
RBJones
ORIGINAL: TowJam
I think you're right. Most of the exhaust comes out the right pipe. I was curious, too and found out that exhaust design is based on complex scientific principles. As 100thRK mentions, the crossover indeed has proven to give better torque/h.p. at the lower end of the rpm curve, the region that most baggers like to cruise in. Since a V-twin's rear cylinder is several inches closer to the back of the bike, that cylinder's exhaust pipe is shorter than the front cylinder's, which creates an imbalance in exhaust flow and back pressure. The crossover helps equalize.
I'm in the minority here, but I think the stock system is fine. It doesn't sound all that good but I can assure you Harley engineers have spent a lot of time and money testing and perfecting the stock Harley exhaust systems that it can perform at its best for the type of bike you own (touring) and still meet EPA guidelines. Is stock perfect? No. I'd like to hear a deeper rumble with no increase in volume. But I have smooth power and performance throughout the range, from a rock bottom pull to winding out. I hesitate to mess with something that works. I haven't had to fuss with dynos, EFI mapping, spending more $$ and all that stuff.
Sound seems to be the primary selection criteria for most people, with looks and performance coming in second and third. These three things don't work in perfect harmony so it always ends up being a compromise situation based on individual preferences. Most experts will say that if you're really interested in performance, the two-into-one exhaust is the best. But many baggers don't think their bikes look right with just one pipe.
For a well-written article on exhaust design, go to this one by Donny Peterson, who writes for American Iron and has many years of experience with Harleys: http://www.heavydutycycles.com/exhaust.htm
Old Apr 7, 2006 | 09:42 PM
wjl24's Avatar
wjl24
The best performance comes from a 2 into 1 exhaust. That's not an arguable point, it's proven. The stock set up is a compromise. It gives the classic bagger look with dual mufflers and good low end torque. Doesn't sound quite as good as true dual but close. But it works off the 2 into 1 principal.
Old Apr 7, 2006 | 10:00 PM
HD Renegade's Avatar
HD Renegade
ORIGINAL: 100thRK
Sorry, but I call BULL$HIT on this one, no way anyone is going to pull 100 HP on a stock motor, with stock front pipes, and slip-ons.
Bob
Old Apr 7, 2006 | 10:24 PM
blowe's Avatar
blowe
ORIGINAL: HD Renegade
ORIGINAL: 100thRK
Bob
It helps to pay attention before screaming BS.
He didn't say anything about running a stock 88.
Look at 100thRK's signature...
100th 2003 FLHRCI SE Hi comp HTCC Big Bore/Six speed ~101 hp/106tq
Old Apr 7, 2006 | 11:26 PM
HD Renegade
ORIGINAL: Oliver Clozoff
ORIGINAL: 100thRK
Bob
Well, excuse me for not reading everyones signature line when I read the posts!!!!!!!!!
Bob
Old Apr 8, 2006 | 01:07 AM
jeepster09's Avatar
jeepster09
[sm=headbang.gif]
Old Apr 8, 2006 | 10:29 AM
100thRK's Avatar
100thRK
It's ok Renegade I will let you off this time. I might have to send my attack taco bell dog after you though!!!!
