"Slip on's"
Old Dec 5, 2008 | 08:03 PM
  #41
PeeTuneYa's Avatar
PeeTuneYa
So, now we are to the point of 02 and open loop. Closed, the sensors run the analog. Open loop, we have a single signal and that turns the system into closed loop is think about it.
When you WOT the throttle, the sensor is now sending one signal and that is the digital as opposed to the analog.
Very simple... Take your normal room light switch. This is digital or electronic is depends on the lawyer speak is the same game is a single volt is sent. So, the lower the number is the richer the jetting say.
If you lift off the gas is that is one signal reading is now the injectors can be turned off on decel is that lean popping is no gas = Lean but not dangerous lean is just a pop on decel. So, there again on the no foot on the gas is open loop = 1 signal not a bunch of analog rheostat type light switch is is = Closed Loop.
Think the air speed cannot keep up is everyone is running perfect no matter the pipe and cleaner is you are no wear near unclogging that pipe is still not there to cause harm is did the bike run hotter with the new mods is you can tell lean is hotter running mod is get it?
shari
Mar 14, 2010 08:38 AM
chris_nelson123
Feb 28, 2010 09:13 AM
RoadGlideBlues
Oct 12, 2009 06:27 AM
brettnbama
Apr 22, 2009 01:25 PM
TODDNVAL
Oct 21, 2008 05:28 PM
