question?
Old Nov 30, 2008 | 04:09 PM
Richpend's Avatar
Richpend
Default question?
Which side is the best side to put a pigtail for a battery tender on the right or left of the bike?
Old Nov 30, 2008 | 04:11 PM
bbrooks1963's Avatar
bbrooks1963
Mines on the right side. It's closer to the wall where I plug my charger into.
Old Nov 30, 2008 | 04:13 PM
Richpend's Avatar
Richpend
So I guess it really doesn't matter!?
Old Nov 30, 2008 | 04:14 PM
gregsworld's Avatar
gregsworld
Mine's left. It isn't as noticable when the bike's parked as the kickstand is on the left side. Just my opinion of course.
Greg
Old Nov 30, 2008 | 04:15 PM
potter's Avatar
potter
My 08 FLHT had one on it from the dealer. Not sure if they put it on or come from the factroy. but its on the right just above the trans.
Old Nov 30, 2008 | 04:40 PM
dcpicks's Avatar
dcpicks
I don't think it really matters. That said, I have mine coming out to the right side away from the battery. With the bike leaning to the left the right side is open and easier to access.
Old Nov 30, 2008 | 04:44 PM
HDV-GLIDE's Avatar
HDV-GLIDE
Use a little strip of velcro on the frame cross member behind the motor and a strip around the battery tender connector and it stays out of the way when not in use. Use some industrial strength velcro and a tiny plastic tie around the connector velcro and it will never fall off.
Old Nov 30, 2008 | 08:15 PM
jfab6969's Avatar
jfab6969
As long as it isn't touching the exhaust it doesnt really matter. Put it to whichever side is closest to the wall that you park it by. Mine came with one and it was on the left side so I moved it to the right side
Old Nov 30, 2008 | 08:31 PM
krusr's Avatar
krusr
Whatever side is closest to outlet in your garage.
Seriously.
Old Nov 30, 2008 | 08:50 PM
Bluesssman's Avatar
Bluesssman
I have mine on the left side mainly because I changed the plugs to 1/4" audio plugs and use the same direct connection to the battery for my heated gloves and cloths. The female plug is mounted to a bracket on my adjustable backrest lever.
