Monster Oval Question
Old Dec 2, 2008 | 07:16 AM
HDV-GLIDE's Avatar
HDV-GLIDE
Default Monster Oval Question
Has anyone with an '09 Street Glide installed the Monster Ovals with the 2008 part number and if so, has there been any clearance issues with the axle nuts???
Reason being, the people at Vance & Hines are telling me that the Street Glide is the only '09 Touring Bike where the '08 Monster Oval pipes fit without an issue.....
As long as they will guarantee they will replace the pipes if they do hit, I don't have an issue installing them. Yes, I got a killer deal on the pipes but would hate to tear everything apart again to replace them.
Old Dec 2, 2008 | 08:09 AM
cpt373's Avatar
cpt373
You need to use the 09 part number there will be clearence issues with the heat shield if you don't, I just installed a set on my 09 Ultra and you can see what the problem would be if they didn't remove part of the heat shield.
Old Dec 2, 2008 | 08:14 AM
HDV-GLIDE's Avatar
HDV-GLIDE
The top of the heat shields are already cut out on the pipes sent to me. I thought the pipes themselves needed to be notched out also...If not, I should be OK.
Old Dec 2, 2008 | 10:10 AM
bigskyhd's Avatar
bigskyhd
The problem with 09 Ovals (at least what I read) vs the 08, was that they needed to be notched in the actual muffler for the rear axle nut to avoid hitting when the bike is completely compressed from hitting a bump. There was some pics on this a while back on the forum, you might try a search and get the info you need. Hope this helps.
Old Dec 2, 2008 | 10:31 AM
cpt373's Avatar
cpt373
My muffler isn't notched, they only removed part of the heat shield
Old Dec 2, 2008 | 11:09 AM
r8rs4lf's Avatar
r8rs4lf
Here you go.....
https://www.hdforums.com/forum/3832882-post14.html
Here is the entire thread..........
https://www.hdforums.com/forum/touri...ter-ovals.html
Search works wonders!
Old Dec 2, 2008 | 01:25 PM
flyingace's Avatar
flyingace
I am the one the prev poster referred to in the two links posted.
They will work on the 09 STREET GLIDE ONLY as stated to you by V&H. (and In my personal experience) I put the bike up on a lift to get full shock extension, and there were no clearance issues.
Again, as V&H stated, they will only work on the SG, (because of the shorter shocks) all other 09 baggers need the 09 version of the mufflers.
Old Dec 2, 2008 | 02:55 PM
HDV-GLIDE's Avatar
HDV-GLIDE
Thank you, I just needed someone else to clarify that for me......I'm breathing a lot easier now......
ken1960
Aug 23, 2010 10:23 PM
Jday53
Aug 29, 2009 06:17 PM
Gordon65
Jul 14, 2009 10:16 AM
ConradM
May 16, 2009 12:41 PM
colaSG
Dec 11, 2008 09:02 AM
