Tuning Pkg
Another point is that even when tuned the true-dual setup won't produce optimal low-end performance, especially compared to the PP. The problem is that you've already spent quite a bit of money on your present setup, but if I were in your shoes I'd remove it all, sell it on Ebay, pull your old head pipes out of the attic, and buy the PP. I'll wager you won't be disappointed in the results. What you'll miss is the stereophonic sound, if that's important to you, as some prefer it over the performance loss. Also, the crossover pipe will be back, which produces more heat on the right leg, so the changeover isn't without its drawbacks, minor as they may be. You'll just need to establish your priorities and go from there.
As a caveat, Jamie's maps tend to favor performance and cooling over mileage, but leaning the cruise range will bring mileage up to stock or near it while not sacrificing performance when you need it. If you ask, Jamie will install a "mileage map" that will help. Personally, I've gone further with leaning the cruise range on the PCIII with great results, but that's another story. I get 38-50mpg depending on conditions, and the performance is still there when I roll it on.
