WANTED: stock shocks
Old Dec 6, 2008 | 04:37 PM
mrbuck's Avatar
mrbuck
Default WANTED: stock shocks
yes thats right i want stock shocks. I'm looking for the right combo, i started with stock lowered HD shocks (like a SG) but they were to short with the extended fenders on my scoot it would drag the rear coming in and out of the driveway. then i tried a set of progressinve 412's 12 1/2" lenght, thinking that 1/2" would get me the clearance needed, but they have more travel which allows the tire to rub the top of the fender in 2up mode. I'm thinkin arnotts are the way to go but funds are way tight,so stockers are the cheapest and hopefully the right answer. Let me know if you can help
Old Dec 6, 2008 | 04:48 PM
FLHT MAN's Avatar
FLHT MAN
i got a new set of take off's ill trade you.....p.m. me
Old Dec 6, 2008 | 05:10 PM
Leftcoaster's Avatar
Leftcoaster
So what are you length are you looking for?
You know you could step up the preload on the 412's so they don't bottom out. If that doesn't work you may need a stiffer spring. Also there is a rubber stopper that slides down on the shock shaft and helps to cushion the the jolt of bottoming out but it also effectively reduces the travel of the shock.
Old Dec 6, 2008 | 05:14 PM
FLHT MAN's Avatar
FLHT MAN
stock would be the 13's right ?
Old Dec 6, 2008 | 05:22 PM
mrbuck's Avatar
mrbuck
leftcoast i have them set at the stiffest, they dont bottom out the shock it just rubs something on the under side of the fender.
flhtman yes i'm lookin for 13's and you have mail
Old Dec 7, 2008 | 09:16 AM
mrbuck's Avatar
mrbuck
I know theres probably 50 set of these out in your garages, hook me up
Old Dec 7, 2008 | 11:45 AM
bagman1's Avatar
bagman1
I have a set of stock 13" from my 07 RG. Pm me if youre interested.
FYI I went with the Progressive std 440's (12-1/2) with full load and tour pack set at the hardest position I would bottom out hitting a 1" bump in the road, I then put the heavy duty spring on and now I have no issues.
Old Dec 7, 2008 | 02:20 PM
mrbuck's Avatar
mrbuck
bagman you got mail
Old Dec 7, 2008 | 05:36 PM
lkr0's Avatar
lkr0
if you dont have them yet, I have set in my garage that I will trade you for your SG shocks
Old Dec 7, 2008 | 08:01 PM
jkoch09ultra's Avatar
jkoch09ultra
I also have a set of 13in air shocks off my 09 UC. Put an Arnott air ride system on yesterday. They are the cats a$$.
