Anyone using Headquarters pro tuner with SERT?
Old Dec 7, 2008 | 11:55 AM
TODDNVAL's Avatar
TODDNVAL
Default Anyone using Headquarters pro tuner with SERT?
Thinking about buying the pro tuner fro HQ. How well does it work, any problems, anyone dyno after using it?
Old Dec 7, 2008 | 05:42 PM
lkr0's Avatar
lkr0
that is the set up I am using, I had kevin put in a base map--which was pretty close. The auto tuner took over after about 300 miles of riding it's dialed in.
there was no need to Dyno, plugs look good, no decel popping, I had one minor issue of it not getting enough fuel at idle coming down from WOT but the tuner learns quickly--don't ask me how it works it just does.
Old Dec 7, 2008 | 06:13 PM
molsen's Avatar
molsen
Curious on your HQ set-up what cams are you running. Did you buy the protuner with your setup or after. I just put together a 103 st, and was wondering about the protuner.
Old Dec 8, 2008 | 07:07 AM
timbakersr's Avatar
timbakersr
I have a super tuner the latest one. Then I had cams (woods) installed and push rods. The dealer then dynoed my bike and I still have a pop on decel.
Was told that they called bob woods and he said that due to the throtle by wire the 08's have it can't be solved.??? So I live with this.
Old Dec 8, 2008 | 07:57 AM
lkr0's Avatar
lkr0
Hey Tim,
I had the dreaded trottle by wire problem, it can be solved check with Kevin on HQs Forum.
Lyn
Old Dec 9, 2008 | 04:57 AM
timbakersr's Avatar
timbakersr
Originally Posted by lkr0
Hey Tim,
Lyn
Hey what is HQ'S FORUM? Please provide more infor. and link. Thanks!
Old Dec 9, 2008 | 09:10 AM
lkr0's Avatar
lkr0
I got the pro tuner when I got the motor kit, running 575 cams, bike running very well.
has not been on a dyno.
tripleb1911
Sep 27, 2014 12:31 AM
freebirdrunner
May 26, 2011 09:09 PM
Born2cure
Aug 29, 2009 10:35 PM
jag1886
Jun 18, 2009 07:28 PM
bigirn
Exhaust System Topics
Mar 25, 2009 11:23 PM
